Is this classic fan relay death? - JeepForum.com
post #1 of 17 Old 09-23-2013, 07:18 PM Thread Starter
Ravie
Left my Wj running while I ran into the bank earlier, ac on. Came back to a check gauges light and a pegged temp gauge.
And no fan.
I have not yet tried it directly to battery to make sure the fan is ok but it did not come back on at any time driving home (i had to stop once)
Is this the relay under the bumper area on the passenger side? If so I see it has been replaced in the past..
Rav
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #2 of 17 Old 09-23-2013, 07:32 PM
Jaspah
This is why I kept my mechanical clutch fan even though I replaced my fan relay. If that thing fails at least I have a backup.
Jaspah is offline
post #3 of 17 Old 09-23-2013, 07:48 PM Thread Starter
Ravie
I6, no tow package = e-fan only. :-(
Ravie is offline
post #4 of 17 Old 09-24-2013, 12:47 AM
cykaaro
More than likely. Did it throw an engine code? Mine did when it went. Test the fan works. If so, replace the relay. When I hit the wreckers, I grabbed a bunch so have lots of backups if it ever goes. Also a overide switch in case it ever goes I can manually put the fan on if it goes I can run it until I can get it fixed.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #5 of 17 Old 09-24-2013, 02:07 AM
BigEag205
Mine is throwing the code for fan relay, but the fans work and hasn't overheated ha. Not quite sure what to think of it.
BigEag205 is offline
post #6 of 17 Old 09-24-2013, 11:20 AM
Jaspah
It could just be stuck on. Not sure how well the fan will take running all the time while the Jeep is running if it is actually doing that.
Jaspah is offline
post #7 of 17 Old 09-24-2013, 11:22 AM Thread Starter
Ravie
No mine didn't throw a code, but it was at 260 and the fan was not coming on, and didn't come on again, even if I switched on the A/C
Ravie is offline
post #8 of 17 Old 09-24-2013, 02:07 PM
Highschool_WJ
Easiest way to tell if the fan is bad is unhook it and wire straigjt to the battery, if it comes on get a new relay
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #9 of 17 Old 09-24-2013, 04:06 PM Thread Starter
Ravie
Yep, I did that just now when I got home and it's the relay.
I'm gonna have to wire a switch in for a couple of days...broke til payday. Ah, the joys of Just Emptying Every Pocket.
Ravie is offline
post #10 of 17 Old 09-25-2013, 02:44 AM
cykaaro
I know that one! Been replacing the suspension since March I think. Only things not done are the track bar and axle bushings now LOL
If you're putting in an overide switch, using all 5 pins from a relay you can make it permanent. Basically when off, the proper fan relay will work and do it's job. Now, if it ever fails, once the switch is turned on, it'll turn on the fan, but stop the power from backfeeding into the system. Not that it's needed, but gives a bit of backup for the fan, unless the fan itself goes. As well, can turn the fan on with the engine off.
cykaaro is offline
post #11 of 17 Old 09-25-2013, 06:55 AM Thread Starter
Ravie
Yesterday I was messing with a temporary wire to get the fan on and I thought both wires needed to be hooked up, but when I hook up only one the fan turns on. What's the deal with that? Is the case grounded already and those two wires are hot wires for speed control?
Ravie is offline
post #12 of 17 Old 09-25-2013, 11:00 AM
Brakeman62
It could be the coolant temperature sensor on the thermostat housing.
Brakeman62 is offline
post #13 of 17 Old 10-05-2013, 09:46 AM Thread Starter
Ravie
Put in the new relay and everything is working again but the CEL hasn't reset... must need to un-and-re-hook the battery...
Ravie is offline
post #14 of 17 Old 10-05-2013, 11:42 AM
Valor
Mechanical fan clutch on the I6 isn't bullet proof. Two winters ago I had the fan clutch and water pump die on me at the same time. Thankfully it was frigid outside. But gotta love not having to deal with this fan relay business.
As for your code, you'll have to manually clear it. Disconnected the negative terminal for a few seconds should do it.
Valor is offline
post #15 of 17 Old 10-05-2013, 12:47 PM
Jaspah
When I replaced mine I just cleared the code with an ODBII reader and it never came back.
Jaspah is offline
