A/Cissue 3rd post Am I in the wrong forum? - JeepForum.com
post #1 of 6 Old 08-25-2011, 06:42 PM Thread Starter
Neal
1983 CJ7
Soooo......
2000 JGC
Inline 6
Common problem with the a/c defaulting to defrost. Looked for vacuum leaks and installed check valve. My blend door works eveytime and so does my cruise control. So I do not think it is vacuum related. The A/C works every time on defrost and defrost/floor. HOWEVER Sometimes the a/c works on the dash vents and sometimes it will not. Blend door seems to work every time. TONIGHT I noticed that while the a/c was on and the knob set to the dash vents the a/c light was dimmer then when I changed the knob to defrost/feet. The light will get brighter and then dim, brighter then dim. WHAT THE WHAT!!! Short maybe, bad connection somewhere? Any suggestions. It is the manual control single zone heater/ AC. The cruise works fine so I am doubting it is a vacuum issue.
Thanks
Neal
Neal is offline
post #2 of 6 Old 08-25-2011, 07:32 PM
Sohcvtec1995
thats what it sounds like, pull the unit out and check connections, its all electric so by you turning the knob it might not be sending the correct signal
Sohcvtec1995 is offline
post #3 of 6 Old 09-03-2011, 08:08 PM
rudes
The problem is most likely the small vacuum tube under the hood on the passenger side by the firewall. This tube feeds vacuum to your blend controls and can develope small cracks. Replace with a rubber line. Don't know about A/c light. May just be button light going bad.
rudes is offline
post #4 of 6 Old 09-03-2011, 09:48 PM
4Tom
Why are you flooding the forum with same posting ?
Bump you post ! If you think it's slipped down to far to be noticed... !
WJ 2001 3.1TD
http://www.jeepforum.com/forum/f22/2001-wj-3-1td-1252959/
Tom
4Tom is offline
post #5 of 6 Old 09-03-2011, 11:28 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
And you STILL haven't given enough, or rather the right, info to help you.
If it's manual temp in a laredo you either have a vac leak it a dead head unit. It's all vacuum controlled.
If dual zone put it in diagnostic mode and compare the codes with the table on wjjeeps.com.
And try to keep it all in this thread if you need more help.try to provide the relevant info too...
ratmonkey is offline
post #6 of 6 Old 09-15-2011, 05:51 PM Thread Starter
Neal
1983 CJ7
bump
bump
Neal is offline
What is wrong with my WJ??????? JeepPimp WJ Grand Cherokee Forum 46 07-08-2011 11:28 AM
Wrong Cat WJ-S51190 WJ Grand Cherokee Forum 11 03-16-2011 06:59 PM
know its the wrong forum coralman WJ Grand Cherokee Forum 6 10-03-2010 05:25 AM
Something is wrong!!! PuddlePirate10 WJ Grand Cherokee Forum 12 09-21-2010 08:47 AM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
