-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Chrome exhaust tip (http://www.jeepforum.com/forum/f310/chrome-exhaust-tip-1589985/)
rdkendrick 09-15-2013 07:48 PM
Chrome exhaust tip
I did a search, but didn't find anything. My '02 Overland had the chrome exhaust tip and I liked the way it looked.
It got totaled in 2007 and I have had an '03 Overland, since then. I'd like to put a chrome exhaust tip on it, but it would have to be clamp on, as I have no access to a welder. Is anyone running with the chrome exhaust tip on anything other than an '02, if so, what do you have? I'd like some suggestions about what to get. I looked at some, but I don't see how they would mount over the crook in the end of my existing tail pipe.
Sent from my iPad using my fingers
bradywgn71 09-15-2013 08:13 PM
Cut the crook off and clamp on a tip?
cykaaro 09-15-2013 08:18 PM
Exactly.
rdkendrick 09-15-2013 09:53 PM
I guess I could do that. What should I use, a dremel with a cut-off wheel, or a sawzall with a metal blade?
Not sure a hacksaw would fit all the way under, not even sure the sawzall will, either.
COL 09-15-2013 10:08 PM
Cut from the bottom up, or the tire side in. Saw-zall or dremel would work but saw-zall would probably be easier
rdkendrick 09-15-2013 10:15 PM
Then what chrome tip would you suggest? I measured and it is a 3" exhaust pipe. So I assume I need 3" inlet to whatever outlet, probably 4 or 5". I am assuming the 3" inlet with have a slit, or cut, so that it will slide on the same size pipe? Then I could clamp it.
When I looked at the tips, I didn't see 3 1/8" or 3 1/4".
bradywgn71 09-15-2013 11:30 PM
http://www.amazon.com/Flowmaster-153...e+exhaust+tips
http://ecx.images-amazon.com/images/I/41sNIt7wxsL.jpg
rdkendrick 09-16-2013 07:23 AM
Originally Posted by bradywgn71 (Post 16041697)
Cool, thanks, guys!
imaguy3 09-17-2013 04:05 PM
Go to an exhaust shop and have them weld one on... When I got my muffler put on they also did a tip. It was $15 for the tip and I think another $20 to weld it on... looks better and much easier!
rdkendrick 09-17-2013 09:07 PM
Sounds like it might be easier to have them cut it and weld it on.thanks. The options are a 3" inlet, but my exhaust pipe is 3 inches, so how do they attach it if they are both 3 inches. Do they put a slit in it, until it is on far enough to weld, or do they use a flaring tool?
Mav-Jason 09-17-2013 09:32 PM
I'd think, given that the part is an 'end' piece, that it is just slightly larger than 3, and will just slide right on to be clamped down.
bradywgn71 09-17-2013 09:49 PM
Flowmaster 15363 Exhaust Tip - 3.50 in. Rolled Angle Polished SS Fits 3.00 in. Tubing - clamp on
rdkendrick 09-17-2013 10:55 PM
That's what I ordered, I had a $25 Amazon gift card that needed to be used.
I'll have the shop guys do it if I am unable.
The time now is 12:34 PM.
