Chk Engine light on p0441, p0161 - JeepForum.com
post #1 of 5 Old 03-16-2010, 11:30 AM Thread Starter
Blackdout00wj
Some help please any1 those are the only codes it has found only symptoms are crappy idle
00 WJ 4.7 Quadra drive, 6.5" IRO Long Arms Projector 8k HIDs, Blkd tail lights,Dual intake
Blackdout00wj is offline
post #2 of 5 Old 03-16-2010, 01:01 PM
Travis873o
google it.
pretty sure po441 is evap purge flow error. just erase that one and if it comes back you might have a problem.
i usually get that code once in a blue moon
FOR SALE: ZJ 231 bezel. 1996 ZJ Lifted
Travis873o is offline
post #3 of 5 Old 03-16-2010, 01:45 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
ezflip is offline
post #4 of 5 Old 03-17-2010, 03:25 PM Thread Starter
Blackdout00wj
Ok so I replaced my bank one sensor two o2 sensor and then erased the codes. I'm still having a crappy idle. What else could it be?
post #5 of 5 Old 03-22-2010, 09:32 PM Thread Starter
Blackdout00wj
Ok light came back on bank 2 sensor 2 is comming up now as well as evap purge malfuntion my plan is to replace the o2 sensor then run some seafoam through the gas/induction/oil see how that does. Any other ideas? Oh and does anyone know if a Dana 30 front axle have seals between the cv boot and the axle housing? I'm having a leak through there after recently swapping the cv axles only the passenger side is leaking and making a rattle/ loose noise. Any help would be much appreciated!
Wondering about my P0161 and what it effects ef1992 ZJ Grand Cherokee Forum 3 07-29-2009 03:31 PM
Code P0161 here one day, next day gone. WHAT HAPPENED??? ef1992 ZJ Grand Cherokee Forum 14 07-20-2009 06:12 PM
P0441 BigItalianBeast ZJ Grand Cherokee Forum 2 12-06-2006 12:10 AM
P0161 - As soon as I started it this morning! WTH! HELP! Polaris Junkie ZJ Grand Cherokee Forum 7 08-28-2006 08:08 AM
P0161 - Which O2 Sensor? Camo ZJ Grand Cherokee Forum 8 03-14-2006 03:38 PM
