Check engine light and oil pressure gauge j - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Check engine light and oil pressure gauge j
CCOR is your 1 stop source for everything Jeep!TJ 5.25" Speaker Adapters - NalinMFGSteinjager TJ tube doors
Unread 06-01-2013, 03:34 AM   #1
Durango323
Wj Check engine light and oil pressure gauge j
Everything thing was fine on my jeep until today in the morning on my way to work the check engine light turned on and the oil pressure gauge would increase every time id step on the gas... Help? Has it happened to anyone else.. It also makes this weird cracking sound in the engine...
Durango323 is offline   Reply With Quote
Unread 06-01-2013, 05:22 AM   #2
wjjeepman34
Oil pressure gauge is functioning correctly, given that you have a 99 and its an actual working gauge and not a dummy gauge. Oil pressure always increases under throttle.
Get the codes for the check engine light, either by using an OBD scanner (autozone will check codes for free, as I'm sure other car parts stores will too), or by using the "key trick", by turning the key from off to on and back 3 times, as in off, on, off, on, off, and lastly on. Codes should come up on the odometer. Report back with codes!
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline   Reply With Quote
Unread 06-01-2013, 10:12 AM   #3
Durango323
I tried that orr on off n thing nd the check engine and check gage light turned on?
Unread 06-01-2013, 07:42 PM   #4
wjjeepman34
If you left your key in the on position, yes your check gauges light would be on. Since the jeep isn't running, there is no oil pressure, and that light will come on when your pressure gauge reads 0. The P0*** code(s) will show up where the odometer display is.
Unread 06-06-2013, 02:23 AM   #5
Durango323
Using your on off method nothing came out but i was able to get the code whichi is causing the light to turnon... P1420 ?
Unread 06-06-2013, 05:10 AM   #6
99SK04GTX
http://www.aboutautomobile.com/DTC/P1420
99SK04GTX is offline   Reply With Quote
Unread 06-06-2013, 06:57 AM   #7
Double E
2000 Laredo V8
Double E's Avatar
The issue you describe is classic to the oil pressure sending unit failing. (Assuming you have the 4.7.)
There may also be a real issue with the oil pressure and the sending unit is telling the truth. Best to check oil level & think of even dropping the pan to be sure there are no clogs on the oil pickup.
In the short term, replace the sending unit. (easy & cheap) Normally the issue of increased revs making the gauge read low happens when the engine is cold...but it only happens to me when it's VERY cold, like freezing.
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote
Unread 06-07-2013, 11:54 AM   #8
Durango323
Ummm actually ihave the 4.0 inline?
Unread 06-07-2013, 01:34 PM   #9
Double E
2000 Laredo V8
Double E's Avatar
4.0 That's fine. Still recommend the advice provided.
