Check engine light - JeepForum.com
post #1 of 19 Old 09-01-2014, 01:55 PM Thread Starter
2000jwj
Check engine light
Anyone know anything about ABS codes 2 4 8 9 12?
2000jwj is offline
post #2 of 19 Old 09-01-2014, 02:21 PM
Capt_Howdy
I know that they are not related to the check engine light.
Capt_Howdy is offline
post #3 of 19 Old 09-01-2014, 02:35 PM Thread Starter
2000jwj
When my light came on I had it checked and those were some of the codes it read off
2000jwj is offline
post #4 of 19 Old 09-01-2014, 03:07 PM
Capt_Howdy
ABS has a light of it's own. it does not use the check engine light.
post #5 of 19 Old 09-01-2014, 03:31 PM Thread Starter
2000jwj
Why did it read off those codes then?
2000jwj is offline
post #6 of 19 Old 09-01-2014, 04:35 PM Thread Starter
2000jwj
It read off code P0138 but the guy told me it read off more abs codes than anything. After I filled up with gas and drove around the light went off
2000jwj is offline
post #7 of 19 Old 09-01-2014, 06:29 PM
Ah673000
Google is your friend.... 0138 is a code for a bad O 2 sensor in bank 2 . Has nothing to do with the ABS system .
Ah673000 is offline
post #8 of 19 Old 09-01-2014, 06:55 PM Thread Starter
2000jwj
That's weird I don't know why he would of told me it read off ABS codes. Just wondering if I should worry about it since the light went off
2000jwj is offline
post #9 of 19 Old 09-01-2014, 07:47 PM
rdkendrick
2003 WJ
You may have been had, or the guy doesn't know what he is talking about.
Sent from my iPad using Electrons
rdkendrick is offline
post #10 of 19 Old 09-02-2014, 04:40 AM
86cj74.2L
86cj74.2L's Avatar
His reader was probably reads ABS as well as check engine codes.
86cj74.2L is offline
post #11 of 19 Old 09-02-2014, 09:06 AM Thread Starter
2000jwj
So should I figure out the ABS codes?
2000jwj is offline
post #12 of 19 Old 09-02-2014, 09:46 AM
rdkendrick
2003 WJ
Most of the time, it is either water in the ABS connector, flaky connection, or dirty sensor. If your light is not on, now, I would not worry about it. Did the guy clear the codes?
post #13 of 19 Old 09-02-2014, 10:10 AM Thread Starter
2000jwj
I'm not really sure how do you know if they cleared them?
2000jwj is offline
post #14 of 19 Old 09-02-2014, 11:20 AM
86cj74.2L
86cj74.2L's Avatar
For me it was a bad front drivers speed sensor.
post #15 of 19 Old 09-02-2014, 03:12 PM Thread Starter
2000jwj
What's this sensor do?
2000jwj is offline
