Hi, Steve here. My check engine light has now come on twice after Fueling. The Gas cap is secure. I fuled with the Plus grade, both times. The light goes out after a few days and starts . The Engine is running great the whole time. Had a friend check for codes, found a O2 sensor going off. I am getting my fuel at Get-Go . What grade do you run in your WJ. And other than a gas cap, has any body else had a touchy check engine light like this.
I have them same problem. I've tried everything. I was told by a veteran mechanic, that most likely the solenoid at the rear canister is sticking open, thus causing the leak code. I never changed mine, because the app on my phone automatically clears my codes. And it doesn't affect anything. Anyway that's the first thing I would look at.
What was the exact code that you pulled? You state it was an "O2 sensor going off". To me, sounds like you have a failing O2 sensor, and that the check engine light coming on when you fuel up is just coincidence. But it could just be the way you worded it also.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
