cheap and easy tow hooks for WJ (writeup) - Page 3 - JeepForum.com
post #31 of 42 Old 06-12-2012, 08:56 PM
kc2mrg
yea if you did that, you might pull the frame off the jeep before the hook gives lol, but i put the hooks in there because the local jeep club requires a tow point on the front just incase so thats why im doing this, i dont really want to have a plate welded into the frame because i do want to put a brush guard on the jeep at a later date and then i will prob re-do the hooks, since i think they will be in the way of a brush guard mount (not sure tho, never seen one) and i do minor wheeling, so i wont be using these hooks all day everyday, just for those just in case situations
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #32 of 42 Old 06-12-2012, 08:58 PM
kc2mrg
and narnwv, if i ever got an after-market bumper or brush guard id re-do the hooks
Flowmaster exhaust
JEEPINWV.COM
kc2mrg is offline
post #33 of 42 Old 06-12-2012, 08:59 PM Thread Starter
WJlover
Originally Posted by narnwv View Post
This sounds like a good idea.
Just remember, most bumpers mount in those frame rails. so if you ever upgrade to a metal bumper, you're going to have fitment issues unless you build the bumper yourself.
their both good ideas just ones better lol.
but by the time im able to actually afford a metal bumper, ill be able to afford a custom metal bumper
plus i may just go with a prerunner kit rather than a big heavy spring sagging behemoth.
prerunner would be good for me anyways because the highest ill ever go is 4" and thats only if the wallet allows it. so de to the smaller lift, i need to do other mods for clearance.
WJlover is offline
post #34 of 42 Old 06-12-2012, 09:03 PM Thread Starter
WJlover
honestly, i only did these hooks as a quick fix for a groups requirements. didnt think id ever have to use them as i too only do light wheeling, and hardly get to do it. but on this one trail, that i had done before, my 4x4 wasnt working and we had to use the hooks. i expected them at the time to come flying off, i was nervous as hell but they held up and held up strong!
WJlover is offline
post #35 of 42 Old 08-04-2012, 02:40 PM
waxon
Crawled this thread. Just got some 10k rated hooks from a junkyard. For 12 bucks for the pair. May do this once it gets cooler out. More for Looks and the possibility of needing a recovery point up front.
2000 WJ- 4.7L, Quadra-Trak, 245/70/16, K&N filter, Black Rock 16X7 wheels, CB radio, Sirius Sat, 2 inch Daystar Budget Boost, ProComp ES 9000 shocks.. more to come
waxon is offline
post #36 of 42 Old 08-07-2012, 11:54 PM
ARdirty
Pull-a-part
I was on the notification for any wjs that came in and a sweet v8 limited exactly like mine came in with minimal steering damage due to a wreck. Why anyone would call this totalled is beyond me but i managed to pick up 2 tow hooks with mounting brackets, 2 hood supports and the grille subframe all for 55$!
ARdirty is offline
post #37 of 42 Old 12-23-2012, 04:03 AM Thread Starter
WJlover
i know this is old but i wanted to update you guys on my own hooks.
no pictures right now, but ill be hand siping my tires tomorrow and ill take the pictures then.
but anyways, i really got to try out my hooks awhile back when i decided to go wheeling without my front driveshaft.
goes without saying eventually i got stuck, VERY stuck. one back wheel sitting in a deep flooded rut, other three on wet mud. one wheel with traction wasnt going to get me out.
after about an hour along comes a stock f-150 driven by a 17 year old girl to save the day (what an ego crusher)
first we tried pulling me forward. hooked up my strap to the hooks (what i did here was a BAD idea...
i ran the strap right through both hooks and then to the back of her truck. pulled the hell out of me, couldnt get me out, eventually the strap fell off because she backed up to far, but i then noticed i bent my hooks inward. (the way i set up the strap created a squeeze effect on them. dumb mistake in a desperate situation, we all have them)
the frame points are what bent inward. the hooks and plates i have installed stayed perfectly intact. when pulling on them the PROPER way, they never budged or bent. and she was pulling HARD (her first time doing any recovery, i thought she was going to rip my jeep in half!)
so the hooks hold up, until dumb mistakes are made.
i still stand by my solution!
oh and in case anyones wondering, eventually we decided to pull from the rear, pulled my whole left side into the deep flooded rut (i thought i was going to be drinking muddy water, ALMOST tipped) and then pulled me straight back.
MAN was that water cold though.
WJlover is offline
post #38 of 42 Old 12-23-2012, 07:18 AM
CoastieShep
Did mine the same as yours, just with a larger thicker chunk of steel, and put a third bolt through the frame and plate. Bounced it off a couple steep inclines yesterday, and not a single deformity. I've seen the stock hooks, and how anybody can say they'd be stronger, is beyond me.
CoastieShep is offline
post #39 of 42 Old 12-23-2012, 08:55 AM
LilLuKe
LilLuKe is offline
post #40 of 42 Old 12-23-2012, 09:29 AM Thread Starter
WJlover
1 hook for 40 bucks.
i made 2 for less that work just fine.
oh, i forgot pictures!
coming up, if my phone works today
WJlover is offline
post #41 of 42 Old 04-26-2013, 12:07 AM
Christianofojai
this is sutch a good idea. i am going to do this as soon as posible.instead of using one 1/4 plate ill sandwitch the fraim with 2 1/8 steel plates.
V8s are like tampons. Every p**y has one.
6 in a row makes it go.
My lug-nut has more torque than your v8
Christianofojai is offline
post #42 of 42 Old 02-18-2015, 07:18 PM
landonmathers
landonmathers is offline
How to: Hid reverse light writeup alwaysHI WJ Grand Cherokee Forum 53 10-29-2013 03:28 AM
Cheap/easy way to put fog lights in a Laredo? MikeJ75 WJ Grand Cherokee Forum 10 02-14-2012 07:58 PM
Warn Front Hitch Writeup negativecreep WJ Grand Cherokee Forum 40 01-15-2012 10:51 AM
could someone do a writeup for me? wj_jeep92 WJ Grand Cherokee Forum 10 09-25-2010 02:52 PM
JK Axles into WJ FAQ/Writeup? theksmith WJ Grand Cherokee Forum 6 05-01-2010 09:23 PM
