Cheap beadlocks... is there such a thing??? - JeepForum.com
post #1 of 10 Old 04-25-2013, 07:08 PM Thread Starter
CCFoundry
I like the look and function of beadlocks but they are so much more expensive than basic steelies. Does anyone make cheap steel beadlocks that have that same look and function?
CCFoundry is offline
post #2 of 10 Old 04-25-2013, 07:30 PM
silentbob21
street locks, or the fake bead locks... probably as cheap as you will get, unless you find a steal on some used ones.
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #3 of 10 Old 04-25-2013, 08:14 PM
wvracer821
http://www.trailworthyfab.com/
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #4 of 10 Old 04-25-2013, 08:14 PM Thread Starter
CCFoundry
Thanks!!! Those are exactly what I'm looking for!!!
post #5 of 10 Old 04-25-2013, 08:23 PM Thread Starter
CCFoundry
Any idea on advantages of 10" vs 7" for a wj? Will that affect backspace requirements. I was originally thinking 8" but it doesn't look like they have them.
post #6 of 10 Old 04-25-2013, 08:30 PM
wvracer821
7" wide?
factory backspacing is around 6" IIRC alot of people run around 4" on aftermarket wheels
Junk: 2000 WJ, 4.0L
Build Thread:
post #7 of 10 Old 04-25-2013, 08:38 PM Thread Starter
CCFoundry
Originally Posted by wvracer821
7" wide?
That was an option for the street locks that I was looking at. I know most guys run 8" wide rims and am trying to understand what affect will running 10" wide rims have.
post #8 of 10 Old 04-26-2013, 12:47 AM
silentbob21
really depends on what size tire you want to run. If you are gonna go with 33x12.5 then you will be fine with an 8" but you can run a 10" as well which is normally recommended but not necessary.
I believe that with an 8" rim the tire will bubble out a little more, and with a 10" rim will be slightly more narrow, but of course this will be just slight and really only have an affect on rubbing issues... which is why most run 4" BS in order to clear the bigger tires.
on a side note, these are sweet... but I cant spend $1000 on wheels I will take to the rocks when I dont really need them
post #9 of 10 Old 04-26-2013, 01:55 AM Thread Starter
CCFoundry
I can't paste anything in here but once you said streetlocks earlier I did a search and found some for $100 each. That's within my budget but I just realized that they are not real beadlocks. I'm guessing that the ring is mostly cosmetic although it still offers some support to the bead. I like the look though and I can't justify dropping a grand to go beat up either... Call us crazy
post #10 of 10 Old 04-26-2013, 07:08 AM
wvracer821
The ring is just for looks. No function at all
Junk: 2000 WJ, 4.0L
Build Thread:
