changing rear differential fluid - JeepForum.com
post #1 of 33 Old 07-07-2011, 06:54 PM Thread Starter
Grand2626
So how important is it to change your rear diff fluid? I have a 2004 with 150k and it still has the original fluid with no problems. I have changed the front diff as the cover was easy to remove. The rear diff looks very difficult to remove, almost like you have to remove the gas tank. Any advice on doing this would be great.
Grand2626 is offline
post #2 of 33 Old 07-07-2011, 07:00 PM
boomersoonerGC
If you dont have a lift you can jack up the body and drop the swaybar and get to it. You will need a pump of some kind to fill it.
Not difficult.
boomersoonerGC is offline
post #3 of 33 Old 07-07-2011, 07:00 PM
99JGCWJ
http://www.jeepforum.com/forum/gtsea...sa=Search#1227
Any of these should answer your question.
SIX IN A ROW MAKES IT GO!!!
99JGCWJ is offline
post #4 of 33 Old 07-07-2011, 08:31 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Very important. The scary thing is that the MAX service life of the diff fluid is 30,000 miles on the "Service Interval A" (driving like a nun in spring time). I guarantee that when you pull the rear diff cover, you'll find a pile of metal shavings and a very worn ring and pinion. Feel the edges of the gears for sharpness, they will be sharp and this is an indication of excessive wear.
My ZJ had been neglected for a long time and both front and rear diffs were very worn and had lots of metal shavings in the diffs when I changed it.
Changing it is really easy. Just jack the body up a few inches and you will get a lot more access to the diff. You don't need to get it off the ground or anything, just gain 6" of clearance for the rear diff cover.
~Richard
billzcat1 is offline
post #5 of 33 Old 07-07-2011, 08:56 PM
Cowboyup94
Your WAY over due! change it. just get the proper fluid.
Cowboyup94 is offline
post #6 of 33 Old 07-07-2011, 09:05 PM
WiCkeDuDe
Be ready for a horrible smell when you pop the cover.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #7 of 33 Old 07-07-2011, 11:06 PM
BLKWJLTD
Haha changed my front differential fluid last week and all i can say is wow. The smell was terrible!
BLKWJLTD is offline
post #8 of 33 Old 07-08-2011, 12:54 AM
Thomahawk
2006 XK Commander
I did it only with a Garage Jack, no need to pull the Sway bar. Come on, it isnt That hard.
Buildthread
Thomahawk is offline
post #9 of 33 Old 07-08-2011, 02:45 AM
TomClancy
Did you just misspell "fluid?"
TomClancy is offline
post #10 of 33 Old 07-08-2011, 04:05 AM
kfxnando
Self loosened the sway bar, for ea acess, difficult to get in there with big hands
did NOT remove the tank
get some ratchet sanders, it makes life easier
and yep, that old oil smell bad
enjoy it
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #11 of 33 Old 07-08-2011, 04:47 AM
99JGCWJ
No, I actually only put 1 f in diff.
99JGCWJ is offline
post #12 of 33 Old 07-08-2011, 08:17 PM
Andymack
Call the dealer and ask what fluid to put in.
The book calls for 80w90 in my book, but the dealer recommends 75w140 if you want to extend service life of the part or if you drive under severe conditions.
- = AnDyMaCk = -
Andymack is offline
post #13 of 33 Old 07-09-2011, 03:37 AM
Thomahawk
2006 XK Commander
Do you have the Quadradrive? Then you need to use 75w-140 and add FM.
Buildthread
post #14 of 33 Old 07-09-2011, 05:33 AM
tjlmbklr
I am guessing it's something close to the smell as the tcase. I just swapped mine and had it split open (old and new) and that smell is horrible)
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline
post #15 of 33 Old 07-09-2011, 05:36 AM
tjlmbklr
enjoy it
WTF is a ratchet sander?
tjlmbklr is offline
Front differential fluid change. BLKWJLTD WJ Grand Cherokee Forum 12 04-13-2013 05:45 PM
noise after changing transfer case fluid WarInc WJ Grand Cherokee Forum 6 06-11-2011 08:40 PM
Thinking about changing my differential fluids, Mopar? uga32 WJ Grand Cherokee Forum 18 05-09-2011 05:52 AM
changing tranny fluid 42RE noeffort WJ Grand Cherokee Forum 34 03-25-2010 06:55 PM
Differential Fluid Change - 2000 GC 4X4 6 Cyl. Harvey WJ Grand Cherokee Forum 6 01-22-2004 04:39 PM
