Changed transmission - JeepForum.com
post #1 of 9 Old 03-23-2010, 03:33 PM Thread Starter
bassfisher999wj
hey guys
My jeep was shifting real rough/sticking from 1st gear to second. I work at a bodyshop at a chevy dealer so I decided to bring it to the mechanic there.
He told me he found pieces of metal in the transmission fluid and that it had to be replaced. He says this was all caused by a valve that wouldn't let enough fluid in. So I bough a rebuilt transmission.
I got it back today and was disappointed. It now starts rough as hell, makes a krrrrr-krrrrrrrrrr-krrrrrrrrr noise more at high speeds and when I let go of the gas it also makes another noise.
Could this all be caused by something he did wrong? Don't really want to go and tell the guy he messed up because I know the guy.
bassfisher999wj is offline
post #2 of 9 Old 03-23-2010, 04:44 PM Thread Starter
bassfisher999wj
My 4 inch lift puts the lower control arms at quite the angle, but I don't think that this could cause the noise, could it? I've had my lift on for a couple months now.
post #3 of 9 Old 03-23-2010, 06:19 PM
CrazyIvan888
When you say it "starts" rough, you mean it starts MOVING rough, or it sounds rough when you start the engine?
If the guy messed up, he needs to know it. Are you sure he knew what he was doing? Being a Chevy mechanic, possibly he wasn't experienced at working on other makes.
Jeep: Every adventure is a repair, every repair is an adventure!
CrazyIvan888 is offline
post #4 of 9 Old 03-23-2010, 06:33 PM Thread Starter
bassfisher999wj
When I start the engine.
He specializes in transmission at the garage. Guess I just feel bad going back and complaining because I know when a client comes back to the bodyshop they are always trying to cheat us.
post #5 of 9 Old 03-23-2010, 06:51 PM
CrazyIvan888
Well, I would take it back to him, tell him what's going on and give him a ride in the Jeep. Once he hears the noises that it's making, it should be obvious to him that you've got a legit problem.
I would do it soon though. The longer you wait, the more likely he is to suspect you of abusing the transmission since he put it in.
Have you checked the fluid and stuff to make sure he filled it properly?
post #6 of 9 Old 03-23-2010, 07:04 PM Thread Starter
bassfisher999wj
Didn't check it, got home and too depressed.
I'm pretty sure he heard it. When he returned it to me he said something like "runs good now apart from your other problems".
post #7 of 9 Old 03-23-2010, 07:10 PM
CrazyIvan888
Other problems, eh? Did he mention what the "other problems" were? This guy sounds suspicious.
And you had no problems or noises like that before the swap, right?
post #8 of 9 Old 03-23-2010, 07:26 PM Thread Starter
bassfisher999wj
My shocks might have made a little bit of noise which he said at the beginning, but apart from that, no.
post #9 of 9 Old 03-23-2010, 08:48 PM
CrazyIvan888
I would take it back to the mechanic, give him a ride so that he can hear and feel exactly what's going on, and tell him respectfully that you think the transmission was either defective or improperly installed since you had no such noises before the new transmission.
If he insists that the noise was there before, then take the Jeep to a different shop and have them diagnose the noise and print you out a repair sheet stating what they think the noise is and about how much it will cost to repair it.
If the independent shop tells you it's a transmission problem, then this guy who did your tranny has most likely screwed up either in the rebuild or the install, and doesn't want to own up to it.
Keep us updated, if it turns out this guy is trying to screw you DO NOT let him get away with it!
What changed for 96+ ZJ? 4Doors ZJ Grand Cherokee Forum 49 03-22-2010 10:48 AM
Just changed my oil and... mr_fsu_guy WK Grand Cherokee & XK Commander Forum 7 02-09-2009 01:38 AM
WTF? Changed my oil and now it wants to die? WHY!! Soft 8 ZJ Grand Cherokee Forum 6 09-02-2007 02:05 PM
changed radiator, what next? rob's zj ZJ Grand Cherokee Forum 4 06-03-2007 07:49 PM
Just got my oil changed *story* coolest_Stan ZJ Grand Cherokee Forum 18 03-03-2005 11:59 AM
