Change of valve cover gasket 3.1TD - JeepForum.com
post #1 of 13 Old 01-07-2014, 03:31 AM Thread Starter
norrleif
Wj Change of valve cover gasket 3.1TD
Need to change valve cover gasket on my WG with 3.1TD engine. There is not much space above the cover. Is if there enough room to lift of the valve cover when the intake pipe above is removed?
norrleif is offline
post #2 of 13 Old 05-14-2016, 05:19 AM
richard44lee
Hi norrleif
are you still around on this forum? I'm just wondering how you got on with changing the valve cover gasket. I have a slow oil leak on mine, well it leaks oil on local use but on a longer run when the engine reach's full operating temp it barely loose's any oil.
Richard.
richard44lee is offline
post #3 of 13 Old 05-14-2016, 08:04 AM
OldGreyV8
Look at the start and the end of the vid...
Its possible with only removing the intake pipe,but much easier to handle with a lowered engine ....
WJ 4,7 HO 2004 Overland,grey, 4" Zone Lift,265/75R16 MT 8x16 AEZ-wheels ,4OFF Winch Bumper+12000lbs
OldGreyV8 is offline
post #4 of 13 Old 05-14-2016, 08:37 AM
richard44lee
"much easier to handle with a lowered engine "
Thanks OldGreyV8, that's the tip I wanted>
Richard.
post #5 of 13 Old 05-26-2016, 03:54 AM Thread Starter
norrleif
Hi Richard,
I have not changed mine, leak is not that bad mainly moisture around the valve cover. Checked the workshop manual and the engine have to be lowered via the left engine mount, intake pipe have to be removed and also the AC compressor line over the valve cover have to be removed. Let me know if you make the change and your findings.
Leif
norrleif is offline
post #6 of 13 Old 05-26-2016, 06:00 AM
richard44lee
Thanks Leif, The gasket has arrived and one day I will crack on with it! When I do the job I will let you know how I get on. (I have been warned that the old gasket sticks to the heads or cover and is a b1tch to remove!).
Richard.
post #7 of 13 Old 05-26-2016, 11:59 AM
CarlJH
2003 WJ
I have been told by a former Jeep mechanic who had my 3.1 in bits more than once that its possible to do the gasket without removing the a/c pipe
CarlJH is offline
post #8 of 13 Old 05-27-2016, 02:26 AM
richard44lee
Thanks Carl, that is handy to know.
Richard.
post #9 of 13 Old 06-06-2016, 11:32 PM
adrian12
hijeep friends, is there any advice for rempving the bolt for the engine mount? there is no place to work too and my bolt is totally rustet and wouldnt go off.
or how can i get off the valve cover without lowering the engine. do i have to cut out the "anti noise materiel" above the cover, i dont know the english name sorry
thanks adrian
adrian12 is offline
post #10 of 13 Old 06-07-2016, 02:53 PM
OldGreyV8
Wj
thanks adrian
look at the pics in the link below...its the hardcore version...
http://images.google.de/imgres?imgur...h=955&biw=1920
post #11 of 13 Old 06-07-2016, 08:17 PM
CarlJH
2003 WJ
The link is for the wrong diesel engine, thats the later german one. This thread is about the italian VM one.
CarlJH is offline
post #12 of 13 Old 06-08-2016, 03:38 PM
OldGreyV8
Cool
But its the same way to do it !!!
Cut out the upper piece ,and there is no need to lower the engine...
post #13 of 13 Old 07-24-2017, 03:52 AM
adrian12
hi jeep freinds
lade, but here is my solution and answer
i lowered the engine, the bolt for the engine mount was faulty but i got it out and then some cm lower and the valve cover can be removed very easily...
now with a new bolt it would never be a big problem and work
thanks
adrian
adrian12 is offline
