chain guide and tensioner - JeepForum.com
post #1 of 42 Old 12-25-2012, 11:42 PM Thread Starter
tommyooooooh
My 02 WJ 4.7 has a loud ticking in in the front passenger side of the valve cover until it warms up. I assumed it was lash adjusters and changed them all out but while doing this I noticed the timing chain looked a little bit loose(quarter inch or a hair more).The ticking also did not go away. So now I am leaning towards installing new chain guides and the tensioners this weekend.
Can I replace the timing chain guides and tensioners without having to mess with the timing or pulling the valve covers again? That drivers side is a pain
Jeep has 65k I don't think I need to do a full timing kit plus I'm to broke for that.
tommyooooooh is offline
post #2 of 42 Old 12-26-2012, 07:43 AM
imaguy3
Are you sure it's internal? Take a long socket extension, place the open end in your ear and the solid end on the valve cover, it acts like a big stethoscope and allows you to hear specific areas better.
Do this and place it on the PCV valve, which is located on the oil filler neck (the exact area you're talking about). I replaced mine with a new one and the little metal piece inside rattles like none other. Sounds like a tick, but if you place the extension right on it you can clearly hear that's the source of the noise.
Another possibility is the exhaust manifolds will often leak, which often sounds like a loud tick until the car warms up.
imaguy3 is offline
post #3 of 42 Old 12-26-2012, 12:11 PM Thread Starter
tommyooooooh
Im 99% sure its internal. I used a mechanics stethoscope on everything and the ticks in the front of the valve cover and i can follow the sound down into the timing cover. If i remove the timing chain tensioner and guides would it affect the position of the timing chain causing me to have to reset the timing.
1995 Zj Sold
2002 WJ 4" rc lift.
Build thread: http://www.jeepforum.com/forum/f22/tommys-wj-build-1478167/
post #4 of 42 Old 12-26-2012, 05:15 PM
coopdc78
Well I do know first hand that when the 4.7 is not running..the driver side chain will feel loose .. I thought the same thing on mine so I replaced it or all of them and no change..
2004 overland 4"long arm lift
2005 wk stock
2000 camaro ss/slp w/10,000 miles
coopdc78 is offline
post #5 of 42 Old 12-26-2012, 05:18 PM
coopdc78
Oh and you cannot replace tensioner or chains without removing valve covers or timming cover.. not hard job but there is a lot involved. Get a Chilton's if ur gonna do it
2005 wk stock
coopdc78 is offline
post #6 of 42 Old 12-26-2012, 07:26 PM Thread Starter
tommyooooooh
I dont want to replace the chains yet i couldn't imagine they'd be stretched out at only 65,000 miles. I just want to replace the chain guides and the tensioners so at least if the tick doesn't go away ill know Ive changed everything I can think of. I would think that'd i'd be ok to just pull the front cover to do it all. I have a chiltons book and in the pictures make it look like i would be able to take off the guides through a couple port on the heads just under the valve cover.
post #7 of 42 Old 12-26-2012, 07:32 PM Thread Starter
tommyooooooh
its also weird the drivers side chain feels loose when the engines off. Thats what lead me to believe that the tensioner was going out. I just don't fully understand why it quiets up after the engine warms up for a couple minutes. I haven't been driving it since i got the ticking and saw how loose the chain was I'm kind of scared of the chain skipping a tooth.
post #8 of 42 Old 12-27-2012, 04:40 AM
coopdc78
Can u verify that its coming from the timming cover? Sounds like exhaust leak
2005 wk stock
coopdc78 is offline
post #9 of 42 Old 12-27-2012, 04:20 PM Thread Starter
tommyooooooh
my only verification is a stethoscope and the hammer hitting the valve cover sound for the first 2 minutes of start up. Only other thing i could think to eliminate that out of the picture would be to change the exhaust manifold gasket.
Someone did throw out the theory of an oil pump not pumping out enough oil to properly pressure up the tensioner? not sure of this theory gonna have to look into and hope i can rule that out. My oil pressure seems fine according to the dummy gauge on the dash but no real numbers.
post #10 of 42 Old 12-27-2012, 04:21 PM Thread Starter
tommyooooooh
so does anyone know if taking off the secondary timing chain tensioner and chain guides off will throw off timing? Im hoping its as simple as take them out put new ones in and put everything back together.
post #11 of 42 Old 12-28-2012, 02:36 PM
jeepster250
The primary chain has to come off before the secondary since it sits behind it. The guides are easy. But if u accident move something u can knock the timing off. Mark it really good. I replaced my timing set the whole thing in 2 days. Timing was a pain in the freaking ***
jeepster250 is offline
post #12 of 42 Old 12-28-2012, 08:30 PM Thread Starter
tommyooooooh
So i started tearing the jeep down so i can replace the secondary timing chain tensioner and chain guides. Hoping nothing moves so i don't have to pull valve cover too and retime. All i know is i thought removing the passenger side valve cover was a pain when i took it off but it don't even compare to removing the damn electric fan and radiator. Couldn't get the power steering fittings out of that cooler bolted to fan to save my life.
1995 Zj Sold
2002 WJ 4" rc lift.
post #13 of 42 Old 12-29-2012, 06:25 AM
coopdc78
Yes sir..I did the whole tip end rebuild and that WAS the hardest part in the whole project..I used a small pair of vice grips
2005 wk stock
coopdc78 is offline
post #14 of 42 Old 12-29-2012, 07:21 AM
LilLuKe
Lol I just replaced my radiator and front main. The fan and radiator definitely suck! I need to do my timing chain, guides, tensioners all that sometime as well.
LilLuKe is offline
post #15 of 42 Old 12-30-2012, 10:18 AM
wjjeepman34
As long as you can keep the chains all hooked up, your good to go. If anything were to move, it would still be in correct timing because everything would still move together.
I had mine all tore apart when I did it (oil pump), so I dont know for sure if you can get to them with all the chains in the way. I dont really remember to be honest.
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline
