CD Player help; shuts off randomly - JeepForum.com
post #1 of 14 Old 03-22-2010, 02:34 PM Thread Starter
drwolcot
Just thought I would ask here if there were any car electronics people out there...
what I have:
Panasonic CQ-VD6503U
and a 4 channel JBL GTO Power Amp running the door speakers
Just the other day working on my Jeep, no where near my aftermarket stereo or aftermarket amp and my Head Unit just decides to turn off like the power button has been pressed. The head unit literally says "Goodbye" like the power button was pressed. The unit still shows that it has power but everything is off (like normal when the unit is turned off when the car is running). It is powered off but now I can't get it to come back on unless I turn the ignition off and back on, then I can press the power button and the unit comes on. Maybe 10 mins later the unit goes through the same process again. It seems to be that it happens at the same interval. I have not timed it to verify that. Sounds like something in the Jeep telling it to turn off???
drwolcot is offline
post #2 of 14 Old 03-23-2010, 11:26 AM Thread Starter
drwolcot
bump
anybody??
drwolcot is offline
post #3 of 14 Old 03-23-2010, 11:30 AM
RJSoAZ
Did you put it in yourself? sounds like the switched lead. check your wiring. If all else fails, wire the switched tot he constant, but remember to turn your radio off
RJSoAZ is offline
post #4 of 14 Old 03-23-2010, 11:37 AM Thread Starter
drwolcot
Yeah I put it in myself..... Its just strange.... It as been in my Jeep for several years now with no issues and its been awhile since I had to pull the unit out. It is just weird cause when it cuts off I can't turn it back on without the ignition cycle.
I am going to check my wiring just haven't had a chance... maybe something came loose????
Yeah if all else fails I could wire to the constant and the good thing about my head unit it won't loose any settings when power is disconnected like that
thanks for the help though
drwolcot is offline
post #5 of 14 Old 03-23-2010, 01:19 PM
GMB34
first of all you have a nice setup.. I'm new to jeeps but have been doing stereo's for years. First and formost check your wiring. Loose wires are a pain.
GMB34 is offline
post #6 of 14 Old 03-23-2010, 01:31 PM
RJSoAZ
oh yeah disconnect the negative terminal first. This should go without saying, but my corner cutting has cost me a head unit or two
RJSoAZ is offline
post #7 of 14 Old 03-23-2010, 02:24 PM
LordHobbit
Overheating?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #8 of 14 Old 03-23-2010, 04:48 PM
GMB34
a deck in a jeep shouldn't be overheating on its own. I guess its possible some way some how you blew the amp but i seriously doubt it.
GMB34 is offline
post #9 of 14 Old 03-23-2010, 04:52 PM Thread Starter
drwolcot
No its not overheating, its like it turns off at a predetermined time interval no matter what the volume level is etc.
I'm going to check the wiring just in case, its just a pita cause it being a double DIN sized unit
drwolcot is offline
post #10 of 14 Old 03-23-2010, 04:55 PM
GMB34
somethin must be wired wrong or came undone. I highly doubt anything got fried. I'm not really sure how speakers amps work but is it possible that something is wrong with that? possibly loose wiring there somewhere to?
GMB34 is offline
post #11 of 14 Old 03-23-2010, 05:18 PM
MurdaJs
I was having similar issues, with it just turning off randomly, only working after turning on and off or pulling the fuse and reinstalling. For me it was intermittent, until it got to the point where it wouldn't work for a few days. Then I noticed one day that when its working, theres a light on the amp that is lit. When its not working, the light flickers randomly. So my guess is after 4 years of bumping the amp had enough
MurdaJs is offline
post #12 of 14 Old 03-23-2010, 05:23 PM
GMB34
check the fuses in the amp.. the flickering light on the amp might have been the light showing it was over heating.. which could be from the amp being old or beaten from loud music or a simple fix is that the fuses on the amp could be blown.
GMB34 is offline
post #13 of 14 Old 03-23-2010, 05:27 PM
MurdaJs
ive checked the fuses before, they were good, but ill double check. The flickering isn't like a constant warning flickering, its like a sputtering, dying, flickering haha. Im pretty sure it has been over heating, probably for about 4 years, because I bump pretty much anytime im driving alone. Thanks though
MurdaJs is offline
post #14 of 14 Old 03-23-2010, 05:31 PM
GMB34
might be time to get a new amp
GMB34 is offline
The dreaded engine randomly shuts off while driving problem. Ved ZJ Grand Cherokee Forum 21 06-05-2016 01:13 PM
wj shuts down randomly while at stop mselby ZJ Grand Cherokee Forum 11 10-27-2009 03:59 PM
4.0 Jeep shuts off while driving, sometimes backfires then shuts off. Help please!! PhillsJeep ZJ Grand Cherokee Forum 10 08-13-2009 08:29 PM
2006 Grand Cherokee Overland 5.7 Hemi 2WD shuts off randomly funinmud WK Grand Cherokee & XK Commander Forum 0 02-05-2008 10:10 PM
The heat randomly shuts off...WTF?! Blueberry2007 ZJ Grand Cherokee Forum 24 03-25-2007 09:44 PM
