CD/AUX Button Stopped Working - JeepForum.com
post #1 of 4 Old 07-12-2013, 09:32 PM Thread Starter
cultcab
I have a 2004 WJ and I've been using an adapter to replace the CD Changer functionality with an auxiliary cable connected to my iPod.
I've had no problems with this for several years.
Just recently, the CD / Aux button stopped working, so I can't switch over to my iPod anymore.
I pulled the radio fuse and re-inserted it so try to reset the radio = no change.
Any suggestions?
cultcab is offline
post #2 of 4 Old 07-12-2013, 09:56 PM
CLUBSFIT
2003 WJ
mine does this and I have to unplug and re-plug in the unit itself, and then hit cd on the deck. I actually lengthened the wires so I could install it in my glove box so I didnt have to pull the radio each time. It is a 10 second job now. Just unplug the large connector that plugs into the converter and plug back in.
03 limited 4.7 H.0., Superchips, TM wire snip mod, K&N drop in with custom intake box. 265/70/17 TKO's
BDS 4" coils, KOR .75 rear spacers, Fox shocks, BDS adj LCA's, A-arm spacer, adj.track bar, quick disc. front links, extended rear links, dual SS, Addco rear sway bar.
CLUBSFIT is offline
post #3 of 4 Old 07-15-2013, 05:16 PM Thread Starter
cultcab
This did the trick. The CD/Aux button started working as soon as a I reset the connector.
I noticed that the radio unit was EXTREMELY hot. The Jeep had been sitting in the driveway (in the California sun) for a few hours, so it was just the ambient air that was heating it up.
I've had a problem in the past with the integrated Navigation unit overheating and erroring out - I would stop working until I let it "cool" down for an hour or so.
I assume that these symtpoms are somewhat related - probably a blown fan in the unit???
cultcab is offline
post #4 of 4 Old 07-15-2013, 09:01 PM
CLUBSFIT
2003 WJ
no, I don't think so... My Cd changer was very intermittent before I got pissed off and yanked it out. I can go a week or so now as long as I don't change the source to radio etc. As soon as the connection is lost,I have to reset the unit.
CLUBSFIT is offline
