Are the ccfl halos adjustable? - JeepForum.com
post #1 of 6 Old 07-20-2013, 08:22 PM Thread Starter
SCAN-MAN
Installed ccfl's, beam is pointed way too high, is there a way to lower it so I don't blind on comers ?
SCAN-MAN is offline
post #2 of 6 Old 07-20-2013, 08:53 PM
Dan_d
The headlight beam or light from the halos?
Dan_d is offline
post #3 of 6 Old 07-20-2013, 09:12 PM Thread Starter
SCAN-MAN
Headlights, low beam is blinding
SCAN-MAN is offline
post #4 of 6 Old 07-20-2013, 09:19 PM
Schlotzky
2007 XK Commander
Yep, if you have the spyder ones, which you probably do.
Get a nice long phillips screw driver and stick it down in the hole in the radiator support beam that the headlights mount to. Fish around a bit and you'll find the gear type thing you turn to adjust the headlights. Shine a flashlight in there to see what I'm talking about. Then just park a decent distance from a wall and bring them down and even. I had to do the same; I thought it was ridiculous that they come out of the box aiming at the trees so as to blind as many people as possible.
Schlotzky is offline
post #5 of 6 Old 07-20-2013, 09:45 PM
Dan_d
I had to do the same on mine as well. The passenger side one I had to take out to adjust because you couldn't get to the gear.
Dan_d is offline
post #6 of 6 Old 07-21-2013, 06:11 PM Thread Starter
SCAN-MAN
Wj
Done!! Many on comers thank you...ridiculous for sure... I should have tested them before blinding even the truck drivers, during a severe monsoon storm..
SCAN-MAN is offline
