Carolina Driveshaft Woe's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Carolina Driveshaft Woe's
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-18-2010, 05:33 PM   #1
xJoshxx
xJoshxx's Avatar
2012 WK
I don't really wanna change my yokes out on my Grand Cherokee.
I recently Inquired About getting a Front Drive shaft With the flanges and this what i was told from Carolina Drive shaft.
Part 1.
Hi Josh.
We offer a shaft that you have to change the yokes at both the axle and the transfer case. This shaft is $318.00 for greaseable u-joints and $333.00 for solid Spicer u-joints. This price includes both yokes.
Please let me know if you have any questions or need additional information.
Thanks much for the inquiry.
My response.
I was more interested in using the Flanges at both ends as I don’t want to change the yokes was looking
Like pictured in this thread on Jeepforum
http://www.jeepforum.com/forum/f13/w...ctures-806580/
has the Flanges on each side.
Part 2
We don't recommend the direct replacement for vehicles with a 4" lift. We can sell you one, but we can't warranty against vibrations or if the ears on the flange snaps. The price on this is $298.00 with greaseable u-joints and $323.00 with solid Spicer u-joints.
SO for those of you that have the flanged Drive Shaft from them. do you have Vibes? or problems? i am Extremely Worried about changing the yoke. specially on the front diff.
I have no experience of any kind messing with diffs and i DO NOT want this $300 venture to turn into 1000.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2
2012 WK2 SRT8
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 10-18-2010, 06:42 PM   #2
xjfever
xjfever's Avatar
1995 XJ Cherokee
You could take it to a driveline shop to have the axle yoke swapped if it is scary for you, the t-case yoke is easy and doesn't have a preload set by a crush sleeve. Just remove and replace, then put your new shaft in.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 10-18-2010, 07:21 PM   #3
sicWJofNWA
hey I'm running a Carolina front DS and i wanted to get the adapter flanges as well but when i ordered mine they were out. so i went with the new yoke package. i was a little nervous when it came time to install the new front yoke but here is what i did. i counted the threads that were exposed on the pinion shaft, took a pic of the orientation of the pinion nut, then went at it with an impact. when it came time to put the nut back on i was just careful not to go crazy with it. that was form months ago and no issues. recently changed the fluid up front and there was no metal in it so all is good. just be careful and do not rush things when putting that nut back on.
sicWJofNWA is offline   Reply With Quote Quick reply to this message
Unread 10-18-2010, 08:30 PM   #4
phant0omx
2012 WK
I was running a J.E. Reel front drive shaft with a flange adapter at the pinion at 4" without any issues at all. I had the one at the transfer case switched to a u-joint yoke flange. I had wanted both sides u-joint, but J.E. Reel made it with a flange adapter in the front, when I asked about the difference between flange adapter and conventional u-joint, I was the flange adapter was actually stronger.
So again, no problems at 4" with the flange adapter.
phant0omx is offline   Reply With Quote Quick reply to this message
Unread 10-19-2010, 11:35 AM   #5
xJoshxx
xJoshxx's Avatar
2012 WK
Cause I not a Crazy HardCore wheeler. and i really do fear screwing up the Front diff.
Just worries me that They won't warranty it against Vibes or if an ear comes off the Flange? .
From the pictures i've seen you would have to REALLY rape the shaft to get a ear to come off
like seen here
2011 WK2 ORA2
2012 WK2 SRT8
Unread 10-19-2010, 01:36 PM   #6
skain8
I would avoid the flange style. Heavier, and more prone to balance/vibration issues by the nature of the design.
As mentioned above, go to a local driveline shop, which would probably charge no more than $50 to *properly* change the pinion yoke. The transfer case yoke is a no-brainer (no crush sleeves or preload to deal with). Get a junkyard Dana/Spicer cv driveshaft (i.e. double cardan) and save yourself even more money with better quality than aftermarket. Locally here in PA, WJ cv shafts can be had for as low as $55! Put fresh quality joints in it (if necessary) and you're still at around $100. Also, the stock front cv shaft is the proper length even at 4" lift. I speak from personal experience.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
Half-Ton axle swap guide
231HD build info
skain8 is offline   Reply With Quote Quick reply to this message
Unread 10-19-2010, 01:42 PM   #7
phant0omx
2012 WK
Well, I'm not much of a hardcore wheeler either, so I suppose depending on your level of wheeling may determine what you should do?
I've read in the past some people like having a flange at the pinion because if a rock hits it the flange takes the beating instead of the u-joint and ears. Whether it's true I am unsure of.
I hope someone with more experience chimes in.
Perhaps you can call around and see what other driveline shops say?
Replied while skain8 replied, he makes good points.
Unread 10-19-2010, 02:29 PM   #8
WiCkeDuDe
changing the pinion is really not all that hard if you mark it and are careful about it.
[U][COLOR="Red"]I Have WJ Stuff for Sale[/U][/COLOR]
[B]
[URL="http://www.jeepforum.com/forum/f126/zj-wj-double-cardon-front-driveshaft-52098707-a-3142201/#post29561665"] Grand Cherokee Double Cardon Front Driveshaft[/URL]
[URL="http://www.jeepforum.com/forum/f126/np-242-hd-v8-transfer-case-99-04-wj-selec-trac-2784426/"]99-04 Grand Cherokee WJ NP 242HD Transfer Case [/URL]
[/B]
WiCkeDuDe is offline   Reply With Quote Quick reply to this message
Unread 10-21-2010, 12:40 PM   #9
xJoshxx
xJoshxx's Avatar
2012 WK
Bump
So from what i have gathered in my searching of the other 4 common sites and my manual.
Crush Sleeve is 500ftlbs MAX and barely starts to crush at 170ftlbs
my manual states to lift the jeep take tires and brakes off then measure In lbs it takes to rotate the yoke. then you undo the Pinion yoke. put the new on torque to where you think it was. measure the force required to rotate it. continue torquing till they match?
Now thats a of work lol what about just removing the tires and jacking it up and doing the same.
I know on the T-case you just unbolt and rebolt.
Carolina Driveshaft has to make things complicated and not warranty the DS if i get the flange adapters.
Which is #1 reason why i contacted them!.
2011 WK2 ORA2
2012 WK2 SRT8
Unread 10-21-2010, 12:46 PM   #10
WiCkeDuDe
You will find to that the nut will tighten up very fast until the crush sleeve snugs up and "crushes" back to where it was. From there you just need to go a little bit more to add some additional crush. Thats why its good to mark it. It takes a very little amount to put too much preload on the bearings. The best way is to measure the preload, but you need a needle type rotary torque wrench in inch pounds.
[B]
[/B]
Unread 12-29-2010, 05:57 PM   #11
volvite
xJoshxx; what did you end up doing for your drive shaft? I have to replace mine now. The CV at the transfercase boot blew and is getting louder and louder. I called Carolina and they told me about the yoke/shaft replacement, but I too am not too sure about replacing the yokes. I'd love to unbolt the flange and rebolt the new replacement. Shoot me a pm if you would.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline   Reply With Quote Quick reply to this message
Unread 12-30-2010, 01:24 PM   #12
mrJ
2002 KJ Liberty
x2^ the PO had a carolina on this that he said was so bad he took it off. im looking at tom woods for when i do it
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 12-30-2010, 02:37 PM   #13
patrick983
the flange is a short cut, if you're into doing things the wrong way or half-a__ing then go for it but it WILL vibe, thats why they don't recommend it on lifted WJ's, the angle is pretty extreme, the flanges make the shaft shorter and therefore, the angles even more extreme. CD has been making these shafts for our jeeps for a long time with a nearly perfect reputation. more than we can say about the other brands out there.
theres tons of write-ups on the pinion yoke/crush sleeve debate, i personally zipped mine off with my impact and zipped it right back on, and havent had any problems, but to each his own. even if you're scared having a shop do it so you cna get the RIGHT shaft on would be well worth the little bit of extra money. i'd be scared to even hit the gas too hard with one of those flanges.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn [B]SOLD and missed very badly[/B]
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline   Reply With Quote Quick reply to this message
Unread 12-31-2010, 11:12 AM   #14
skain8
Two wrongs don't make a right.
231HD build info
Unread 12-31-2010, 11:14 AM   #15
mrJ
2002 KJ Liberty
explain? i was going to go with the whole she-bang, not just one or two parts
