Cant seem to fix my jeep :( - JeepForum.com
post #1 of 8 Old 01-30-2014, 09:57 AM Thread Starter
jessebrown
I I have a loud humming coming from the back end of my WJ and I finally came to the convulsion the wheel bearing was going out (cause of the leaking) got it replaced and it's still humming.... Almost like a grinding ?
Any ideas?
2002 WJ 4.8L NV247
2002 Jeep WJ 4.7L V8 247 transfer case.
6.5" rustys lift.
jessebrown is offline
post #2 of 8 Old 01-30-2014, 10:13 AM
fosterjd79
Did you look at the diff and shaft joints?
fosterjd79 is offline
post #3 of 8 Old 01-30-2014, 10:16 AM Thread Starter
jessebrown
Diff fluid is good. I drained and filled it.
6.5" rustys lift.
post #4 of 8 Old 01-30-2014, 10:57 AM
fosterjd79
Did you put the limited slip fluid in? And what the rear drive shaft? Check the joints.
post #5 of 8 Old 01-30-2014, 10:58 AM Thread Starter
jessebrown
Yeah I did all that. Which joints?
6.5" rustys lift.
post #6 of 8 Old 01-30-2014, 04:33 PM
99WJ539918
Sounds like carrier and pinion bearings. Very common issue.
Build Thread
99WJ539918 is offline
post #7 of 8 Old 01-30-2014, 04:47 PM
pinky2252s
Yep. Id be willing to bet on pinion bearing(s). It was most likely run pretty dry at somepoint, and the bearings paid the price.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #8 of 8 Old 01-30-2014, 11:25 PM Thread Starter
jessebrown
Thanks y'all!!!
6.5" rustys lift.
