can we install clutch fan on 4.7Ho engine - JeepForum.com
post #1 of 9 Old 02-14-2014, 06:35 PM Thread Starter
AliAbed
Wj can we install clutch fan on 4.7Ho engine
Hi can we install clutch fan on overland engine,thanks .......
AliAbed is offline
post #2 of 9 Old 02-14-2014, 06:56 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I have a clutch driven fan on a non-HO WJ 4.7L, but I'm throwing codes for the hydraulic fan.
Wheelin98TJ is offline
post #3 of 9 Old 02-15-2014, 12:28 AM Thread Starter
AliAbed
Thanks ,Does its cool good and doesnt overheat at idle can i install this clutch fan on my Ho engine
AliAbed is offline
post #4 of 9 Old 02-15-2014, 05:55 AM
narnwv
narnwv's Avatar
No. Why would you want to? You have the better hydraulic fan setup? Something wrong with it?
Typing on phones sucks
~Aaron
narnwv is offline
post #5 of 9 Old 02-15-2014, 06:29 AM
86cj74.2L
86cj74.2L's Avatar
Connect the solenoid to the connector and the code will go away.
The hyd fan is a great setup.
It's not great if its broken though.............
86cj74.2L is online now
post #6 of 9 Old 02-15-2014, 11:15 AM
Wheelin98TJ
JEEP FREAK
Thanks for the suggestion.
The WJ donor I used for the TJ drivetrain swap had front end damage, so most of the hydraulic fan setup was trashed.
post #7 of 9 Old 02-16-2014, 02:25 AM Thread Starter
AliAbed
guys i want to increase the cooling,does it work if i install it on water pump
AliAbed is offline
post #8 of 9 Old 02-16-2014, 03:04 AM
Thomahawk
The 04 front radiator and fan was upgraded to improve cooling, dont know why you want to downgrade.
Ig you have problems with the cooling something must be wrong.
What about an extra trans cooler, lot of members to That mod to "save" the Transmission.
Or taurus E fan upgrade mod, check them out.
Buildthread
Thomahawk is offline
post #9 of 9 Old 02-16-2014, 03:32 PM
multmigs
2003 WJ
Buy new factory parts and use good coolant if not an additive like redline water wetter.... The hydro fan setup is about as good as it gets without going full custom dual electric fans...
multmigs is offline
