Can't decide on my next lift. Please Help. - JeepForum.com
View Poll Results: Which lift should I do next?
3.25" by way of adding .75" spacers to current springs 4 36.36%
4" by way of IRO springs 6 54.55%
4.5" by way of adding 2" spacers to current springs 1 9.09%
Nothing, why would you mod a WJ? 0 0%
Voters: 11. You may not vote on this poll
post #1 of 13 Old 01-03-2011, 08:25 PM Thread Starter
Blkdvll
I'm not happy at 2.5", and will be going up. However, I can't decide how big, or by what means. I don't wheel super hard and honestly, the 2.5" has served me fine. Unfortunately it's leaving a lot left to be desired visually.
I am also a single dad so money also has some say in it. Tell me what you guys think, and why.
2004 4.0L w/242 WJ - Front tow points, Rear D Shackel, 3"/2.5" lift, 245/75 Falken ATs, Sway Bar delete, Overland Sliders, T-Case Skid, Hella 500's, Halved Bumper, Custom Rad.Core Skid, Soft 8's, MV50 OBA, Hi-lift/lift mate, shovel, (1st)On-Board Cooler, OME S.S., Rola Basket.....more soon
Blkdvll is offline
post #2 of 13 Old 01-03-2011, 08:48 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Depends on your budget. Going up to 4" will require changing a lot more parts. Going to 3" will need a few parts like a trac-bar, and swaybar endlinks.
xjfever is offline
post #3 of 13 Old 01-03-2011, 08:49 PM
ChiliFrei64
based on your options.. you only have 2 choices
Don't mod it
or .75" spacers
Going to 4"+.. you're gonna need more than just springs(or 2 inch spacer to your current springs)
If your lookin to keep it on the cheap, anything 4inch plus is NOT the way to go
02 Grand Cherokee Laredo, 4.7l, Selec-Trac, FBG 2inch Budget Boost, LT245/75/16 Hankook DyanPro ATM's, Hella 500's
SE Michigan Jeep Club -
Bacon!! - http://baconindex.blogspot.com
ChiliFrei64 is offline
post #4 of 13 Old 01-03-2011, 09:07 PM
rfjeeper
If you go 4in. then might as well get the IRO 4in. LA lift,it will ride better then a SA 4in. lift but will also cost twice as much to buy,and if you have the dreaded rezeppa front driveshaft you will have to replace it too reguardless of LA or SA lift,it just depends on how much you wanna spend to just make it look good,but they do look cool lifted up.The zone and RCX 4in. lifts are both good and cost bout same 700 to 750 and the IRO LA cost bout 1350.00.
rfjeeper is offline
post #5 of 13 Old 01-03-2011, 10:07 PM Thread Starter
Blkdvll
Here's my thinking:
Trac-bar is already going to be purchased regardless of the additional lift. So at 3.25" nothing else will be required. Correct? Est Total: $320
At 4": Front Sway bar is removed from vehicle, so only rear links will be needed. I will need a 1" drop for the transfer case. Est Total: $400
At 4.5": Max for SA right? Same parts needed as 4" right? Est Total: $350
Blkdvll is offline
post #6 of 13 Old 01-03-2011, 10:25 PM
robd2003
Do not DITCH your front sway bar! Its DANGEROUS and especially if your a father you want to be as safe as possibly. you could get adjustable front sway bar links with QUICK Disconnects if you wanna wheel it. At 4" some people need the transfer case drop some dont. my friend ran 6 1/4 lift with no drop...
4" lift (Coils, Shocks, Sway bar end links, bumpstops. Adjustable front short arms. adjustable trackbar, A-arm spacer) I think thats all?
robd2003 is offline
post #7 of 13 Old 01-03-2011, 10:28 PM Thread Starter
Blkdvll
It's only dangerous if you drive like an idiot.
At 4" the LCA dont HAVE to be replaced. I should add that whatever one I finally decide on, parts will continued to be added to over time - including adjustable SA.
Blkdvll is offline
post #8 of 13 Old 01-03-2011, 10:33 PM
Scibbyz99WJ
there are 300 million other drivers on the road, whom we must assume are all idiots. it is not IMHO it is not worth the risk.
ive ridden in a car with no front sway bar. not a comforting ride at all.
plus. sway bar links are CHEAP compared to other mods. so why the heck not
http://store.fatbobsgarage.com/jeep-...004-p8361.aspx
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #9 of 13 Old 01-03-2011, 10:34 PM
robd2003
Not only if you drive like an idiot but if some OTHER drive ignores your safety as well as theirs and you need to avoid quickly things could get UGLY, i had my front disco'd after wheeling, and was going through town when i look over to see a drive turning left and heading straight for me! it was hell avoiding the accident. then i realized i never reconnected...
I would spend the extra :
http://www.ironrockoffroad.com/Merch...ry_Code=XSPJKS quick disconnects $159.99
http://roughcountry.com/jeep_xtras_1131.html $59.95
robd2003 is offline
post #10 of 13 Old 01-03-2011, 10:56 PM Thread Starter
Blkdvll
Like I said, things would continue to get modded.
Please back on topic as for as which lift is right for me. Main two options I am considering are the 3.25", and 4".
Blkdvll is offline
post #11 of 13 Old 01-03-2011, 10:58 PM
robd2003
posted links to help with your lift... quick disconnects for if you wheel your jeep. the cheaper for you and most cost effective would be to go with a 3" lift. still with disconnects
robd2003 is offline
post #12 of 13 Old 01-03-2011, 11:16 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Going higher and ditching the sway bar entirely is a bad idea. Be sure to budget for end links.
At 3.25" you will need the spacers, track bar and end links/discos.
At 4" you will likely need a front driveshaft as well and you should also add longer/adjustable control arms to correct the caster and prevent/reduce death wobble. You'll need a rear a-arm spacer as well. Piecing together a 4" lift on the cheap is going to mean cutting corners and I don't think that is a good idea for your Jeep or your kid(s). Take your time and do it right. The Zone 4"is one of the better values in a 4" lift.
~Richard
billzcat1 is offline
post #13 of 13 Old 01-04-2011, 04:38 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You should try removing the swaybar endlinks and drive the jeep somewhere secluded with no other traffic. Once you see how bad it performs you will see that it is needed. At 4" of lift the problem will be worse. Coil spring suspensions need the swaybar to keep body roll at a minimum, leaf sprung vehicles are more forgiving without the swaybar. At 4" you will need the A-arm spacer also. If you run stock control arms at 4" of lift the tires will be pulled toward the center of the jeep (front tires pulled back to rear of wheel wells, rear tires pulled forward) This will limit tire size you will be able to run. You will be better off to stay at 3" if you don't want to do the other upgrades.
xjfever is offline
4 inch teraflex lift vs IRO 4inch lift??????? anden02 WJ Grand Cherokee Forum 50 11-01-2010 10:46 AM
