Can rear rotors warp?? - JeepForum.com
post #1 of 38 Old 02-04-2012, 03:58 PM Thread Starter
JeepPimp
Replaced my front rotors for the 2nd time in 7 months. Still having the same problem when I try to stop quickly at high speeds. The front end shakes abruptly with a loud humming. (Not an axle problem since it is quiet while I'm driving.) I replaced the rear brake pads 6 months ago and didn't notice any damage to the rear rotors then?
Should i be replacing the rear rotors? I didn't think this was a problem with the rear as much as the front.
Please help, thanks
2004 - Grand Cherokee Freedom Edition
JeepPimp is offline
post #2 of 38 Old 02-04-2012, 04:19 PM
jeep04
Front rotors are normally the cause of the steering wheel shaking while braking, the rear rotors you would feel in the brake pedal more so then the steering wheel.
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline
post #3 of 38 Old 02-04-2012, 04:25 PM
jeep04
Also even new rotors can cause vibation from being out of round, while i was the manager of midas for a few years we use to buy the cheapest garbage rotors for the customers cars and they would return saying that its worse then before.
But after a few times of this happening we would measure rotor run outon a new rotor and it would be out of the limits.
jeep04 is offline
post #4 of 38 Old 02-04-2012, 04:25 PM Thread Starter
JeepPimp
Ya, I deffinitly don't feel the shaking in the steering wheel. More underneath the vehicle
JeepPimp is offline
post #5 of 38 Old 02-04-2012, 04:30 PM
jeep04
You might want to check tie rods or trac bar bushing , but that doesnt sound like a brake issue if its coming from underneath and you dont feel it in the pedal or steering wheel.
jeep04 is offline
post #6 of 38 Old 02-04-2012, 06:01 PM Thread Starter
JeepPimp
i slightly feel it in the brake pedal. it only happens when applying the break following high speeds coming to a quick stop.
JeepPimp is offline
post #7 of 38 Old 02-04-2012, 06:02 PM Thread Starter
JeepPimp
how do i check for these?
JeepPimp is offline
post #8 of 38 Old 02-04-2012, 06:36 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
My money's on front wheel bearings.
~Richard
billzcat1 is offline
post #9 of 38 Old 02-04-2012, 06:48 PM
jeep04
do you hear any humming sound that isnt normally there, if so then it might be the wheel bearing.
jeep04 is offline
post #10 of 38 Old 02-05-2012, 06:16 AM
TeleBruce
have you ruled out the ABS kicking in during a hard stop? That causes a vibration/humming that is normal, but it has to be a hard enough stop to make the car attempt to skid of course.
TeleBruce is offline
post #11 of 38 Old 02-05-2012, 06:22 AM
Rocklobster
You need to check:
Wheel bearings(both sides)
Ball joints(all 4) my money is here,
Tie rod ends(all 4) and here
Track bar(mounts,bolts,bushings) and here
Rocklobster is offline
post #12 of 38 Old 02-05-2012, 09:59 AM
jeep04
Get someone who knows what their looking at and have them climb under the front end while you move steering wheel back and fourth a little and look for things that are moving that shouldnt be.
As far as bearings, jack up the front end and grab the tire at 12 and 6 and move up & down, there should not be any play. While its up grab at 3 & 9 and same this will check tie rods.
jeep04 is offline
post #13 of 38 Old 02-05-2012, 10:22 AM
Rocklobster
I think he means 12 and 6 to do the bearings then 3 and 9 to check BALL JOINTS. You will be feeling for ANY play.
I didn't re-read your first post but how many miles are on this truck ?
All this stuff might need to be done anyway.
post #14 of 38 Old 02-05-2012, 10:40 AM Thread Starter
JeepPimp
105k
Thanks.. I will check for these as soon as I can get to my car jack
JeepPimp is offline
post #15 of 38 Old 02-05-2012, 10:41 AM Thread Starter
JeepPimp
thanks for all the replies guys. I will check for the bearings, tie rods asap and get back to you
JeepPimp is offline
2000 WJ warped rotors...New calipers or just replace rotors/pads? Obababoy WJ Grand Cherokee Forum 25 06-12-2014 12:20 PM
best rotors MoparMan1990 WJ Grand Cherokee Forum 6 11-16-2011 06:12 PM
Rotors albe22 WJ Grand Cherokee Forum 2 05-31-2011 02:48 PM
rotors bhowland WJ Grand Cherokee Forum 2 07-12-2010 10:14 AM
Rotors patreiche WJ Grand Cherokee Forum 4 05-07-2010 01:20 PM
