can i just swap the axles? - JeepForum.com
post #1 of 9 Old 03-10-2010, 09:21 PM Thread Starter
patrick02wj
so some of you might already know but i bent my front axle in my wj and have been driving my truck and i want to get back in the jeep and next thursday i am finally gonna get a chance to fix it. what i was wanting to know and have been searching for is a way to know what wj to get the axle from at the pick and pull. there are different years but no limited like mine, they are all laredos. so what i was wanting to know is there some way to look at marking or tags on the axles and know what gears they have or what... how do i choose which one to pull?
2002 WJ I6, IRon Rock Offroad 4", JKs adj. trackbaR, Doetsch Tech 8000 Prerunner Shocks, 275/70/17 BFG AT, Black Moabs, tinted tails, Hellas
Alpine IVA-W205 Double din, JL Audio 10w7, Fosgate POWER 600/2, Fosgate POWER 400/4, FOCAL 165V30
patrick02wj is offline
post #2 of 9 Old 03-10-2010, 10:12 PM
Rickyb
First you need to find out what front axle you have, I would assume a dana 30, so look for one that has a dana 30 and it either cv or ujoint (whichever one you have, get that one). Remove your old one, install PNP one.
Rickyb is offline
post #3 of 9 Old 03-10-2010, 10:14 PM
GraKee99
Rapist Wit
GraKee99's Avatar
All stock WJs have dana30 and cv joints, none ever came with u-joints and he needs 3.55 gears so you can't get it from a V8 but not all I6s have 3.55.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 9 Old 03-13-2010, 06:38 PM Thread Starter
patrick02wj
ok so dont get one from a v8. that shold be easy. is there any way to tell what gears the axle has though? i mean there has to be something.. doesnt there??
post #5 of 9 Old 03-23-2010, 09:09 AM
muddigger
should be a tag on the pumpkin attached with the cover bolts that will give you the specs of the housing
muddigger is offline
post #6 of 9 Old 03-23-2010, 06:45 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if no tag, pop the cover and look at the numbers on the ring gear. 41 11 is a 3.73 ratio gear. since there were only two ratios offered stock, if it's not that number it's the one you need.
ratmonkey is offline
post #7 of 9 Old 03-23-2010, 06:52 PM Thread Starter
patrick02wj
yeah i found one.. and have already done the swap. took me a long time, i took my time and got it all done. i now just need a new driveshaft bc the diff has like a cone looking thing instead of the t looking thing. for got what its called. i have plans this summer for going bigger so im just gonna wait till then for a new driveshaft i think. but yeah its all done. gonna retourqe everything again this weekend. i was gonna take pictures but i didnt want to get my dads $800 camera greasy
post #8 of 9 Old 03-23-2010, 07:04 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
they call it a rezeppa joint on the wj driveshafts. there's about 5 different shafts offered for the wj.
post #9 of 9 Old 03-24-2010, 04:40 AM
jeepheller98
i have a spare CV style driveshaft and both yokes if your interested perfectly good
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
doing a complete axle swap (front&rear). What axles should i get?? FST1994ZJ ZJ Grand Cherokee Forum 14 02-09-2010 02:26 AM
Axles in ZJ Straight six verses axles in Zj V8 deltl1ks ZJ Grand Cherokee Forum 10 01-27-2010 07:34 PM
Looking to Swap TC and Axles... kaellis77 ZJ Grand Cherokee Forum 5 07-30-2009 10:40 PM
d44 axle swap or yukon axles blu_wj ZJ Grand Cherokee Forum 6 04-12-2009 03:21 PM
All direct swap axles Jones ZJ Grand Cherokee Forum 48 01-19-2009 08:08 PM
