Can I add +1" spacer to upcountry Overland without replacing shocks? - JeepForum.com
post #1 of 15 Old 07-24-2013, 07:09 AM Thread Starter
PatriotUSMC
Thanks for any help!
PatriotUSMC is offline
post #2 of 15 Old 07-24-2013, 07:15 AM
slicvic19
Yes, the upcountry springs are 1 inch taller than others. Many people have a 2"BB with stock shocks, myself included and it rides the same in my opinion.
slicvic19 is offline
post #3 of 15 Old 07-24-2013, 07:25 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
My buddy and I just put a 2" spacer on his 5.9 ZJ Overland. The stock shocks will not be long enuf for you to make use of the lift. The stock shocks will act as limiting straps.
D3<!L!>3D
S8NNG8 is offline
post #4 of 15 Old 07-24-2013, 08:22 AM
harkinsc
Tell us more about this ZJ Overland...
harkinsc is offline
post #5 of 15 Old 07-24-2013, 08:28 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
After putting in the 2" spacers, I grabbed one of the stock shocks to see if they'd be usable. The only way they'd go on was at full reach.
D3<!L!>3D
S8NNG8 is offline
post #6 of 15 Old 07-24-2013, 08:46 AM
Jeeples
Jeeples's Avatar
There isn't a ZJ Overland...
BOT:
You might be able to get away with stock shocks if it's a street queen, otherwise you'll end up blowin' 'em out pretty quick if you do any wheeling.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 15 Old 07-24-2013, 08:50 AM
harkinsc
BOT:
harkinsc is offline
post #8 of 15 Old 07-24-2013, 08:58 AM Thread Starter
PatriotUSMC
BOT:
Ok that is my concern, I want to be able to do some mild wheeling. Thanks!
2002 WJ Overland (Upcountry, 4.7 HO, Quadradrive).
1997 XJ Sport 4" Lift, 31's.
ΜΟΛΩΝ ΛΑΒΕ!
post #9 of 15 Old 07-24-2013, 09:07 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
BOT:
My mistake, thought it was one. Nonetheless, the stock shocks wouldn't fit.
D3<!L!>3D
S8NNG8 is offline
post #10 of 15 Old 07-24-2013, 09:10 AM
Jeeples
Jeeples's Avatar
I'd highly recommend Bilsteins for replacement shocks.
Jeeples is offline
post #11 of 15 Old 07-24-2013, 09:11 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
That happens to be what we used on the ZJ. He loves 'em!
D3<!L!>3D
S8NNG8 is offline
post #12 of 15 Old 07-24-2013, 09:39 AM Thread Starter
PatriotUSMC
Unfortunately I'm not going that route quite yet. Stock shocks ride just fine and I don't need a lift quite yet. Someday.
ΜΟΛΩΝ ΛΑΒΕ!
post #13 of 15 Old 07-24-2013, 04:19 PM
alfaitalia
I have three quarter inch spacers on top of my standard up country (same length as over land) springs....they don't make any one inch spacers for the WJ as far as I can tell) and I off road her all the time and never had a problem. My shocks are not acting a limiting straps at only three quarters over std up country height and as std shocks are the same length as uc ones then I can't see you having a problem.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #14 of 15 Old 10-15-2013, 10:20 PM Thread Starter
PatriotUSMC
Great that is what I needed to know! Anyone else with Upcountry and 3/4" spacers that can verify it's safe to leave the pavement? The last thing I need is to blow out a shock up in the woods.
post #15 of 15 Old 01-22-2014, 10:54 AM Thread Starter
PatriotUSMC
Bueller......
ΜΟΛΩΝ ΛΑΒΕ!
