A/C wont recharge! - Page 3 - JeepForum.com
post #31 of 39 Old 06-17-2013, 02:40 PM
cykaaro
With system evac'd low side will sit at -30 and needs to hold or it's leaking. Operating I've been told low side is typically between 40-60, high side can get as upwards to 450.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #32 of 39 Old 06-17-2013, 06:43 PM
86cj74.2L
86cj74.2L's Avatar
For the record. You either have a orifious tube or a TXV. Not both.
86cj74.2L is offline
post #33 of 39 Old 06-18-2013, 05:54 AM
86cj74.2L
86cj74.2L's Avatar
Here is the AC performance chart
post #34 of 39 Old 06-18-2013, 06:57 AM
lazyWJ
2006 XK Commander
CJ, thanks for posting that up. I found it in some older threads where you posted it before and it was quite helpful to me.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #35 of 39 Old 06-18-2013, 08:20 AM
JeepAdiction
Thanks for the chart. Installed a rebuilt 4.7 in daughters o4 Limited last night. Runs much better than the old one. Thought I would charge her AC this weekend so as to not overheat the new engine this week. It is to be high 90's all week.
56 Willys PU 4X4 Fuel Injected small block Chevy
99 Cherokee XJ 4.5" Rough Country Lift
04 TJ Rubicon 4.5" Rubicon Express Lift
13 Grand Cherokee Limited
JeepAdiction is offline
post #36 of 39 Old 06-18-2013, 08:22 AM
narnwv
narnwv's Avatar
A/C has nothing to do with engine temperature, other than it can make the engine run warmer when it's operational.
~Aaron
narnwv is offline
post #37 of 39 Old 06-18-2013, 08:36 AM
JeepAdiction
Exactly
post #38 of 39 Old 06-21-2013, 01:48 PM
JeepAdiction
Daughter has 400 miles on new engine. Running great. Just charged the AC. It is 94 degrees out so I set the low side at 43 PSI. Nice and cold. Told her to keep an eye on the engine temp. She is very happy. Wants to start hauling her ATV around now.
post #39 of 39 Old 06-21-2013, 06:22 PM
86cj74.2L
86cj74.2L's Avatar
If you started with a empty system total capacity is 24oz. Or sucking two 12oz cans empty.
