A/C Vents change to defrost when..... - JeepForum.com
post #1 of 5 Old 07-29-2013, 10:54 PM Thread Starter
grussell
I accelerate. Changes back to vents cruising at a steady speed or at idol. Push the pedal down for fairly quick acceleration and the vents stop and defroster blows. Probably a vacuum leak somewhere, but has anyone had this issue?
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #2 of 5 Old 07-30-2013, 02:52 AM
js12278
many have had the issue. Vacuum leak somewhere.
js12278 is offline
post #3 of 5 Old 08-01-2013, 06:54 PM
mycreativename
Have the same issue, just learned to live with it cause I don't feel like chasing down a possible leak.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #4 of 5 Old 08-01-2013, 08:04 PM
doityourselfMM
doityourselfMM's Avatar
Try a 'Search' for vacuum or vacuum leak.
doityourselfMM is offline
post #5 of 5 Old 08-01-2013, 09:43 PM
joeisalsocool
Mine was at the check valve, right next to the intake manifold. The valve itself was fine, but the hose connections were slightly loose. Wrapped it in electrical tape, good to go.
joeisalsocool is offline
