A/C Randomly Turns On - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > A/C Randomly Turns On
Threaded Fixit Weld Washers!Why yes, we do still offer our Jeep Forum discount--code i2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 03-26-2004, 12:00 PM   #1
Astorm
My 00 WJ has the dual-zone climate control, and sometimes my A/C randomly turns on. I noticed this when all of a sudden the air got real cold. I don't have the fan set on AUTO, but it still does it.
Any Ideas Why?
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline   Reply With Quote
Unread 03-26-2004, 01:56 PM   #2
Meerkat
Any Ideas Why?
Mine isn't nearly as new as yours, so I don't know for sure about your controls, but on mine, there are two auto functions, one for fan and one for temperature. It's the temperature control that activates the A/C or heater. If you have a temperature number showing in the display, then the control is in auto. You have to select 'OFF' or some other position to control it manually.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Unread 03-26-2004, 03:36 PM   #3
Astorm
yeah, its got the digital display, but I thought the only way it would turn on the A/C was if you pushed the button
Quadra-Drive
Addco
K&N FIPK/RamIt
Every Option
Unread 03-26-2004, 05:39 PM   #4
Meerkat
Nope, that A/C button is for when you want to run it manually and control which vents it comes out of.
Warren
Unread 06-05-2004, 06:21 PM   #5
dylanemcgregor
OK, so I'm pretty confused about how to get my climate control on my '97 ZJ to work like a "normal" climate control system. I want to have the vents on, and I'd like some limited control over the incoming air temp, but I don't want the AC to ever kick on unless I tell it to. Any suggestions on how to accomplish this?
-Dylan
dylanemcgregor is offline   Reply With Quote
