A/C help with 99 Grand cherokee - JeepForum.com
post #1 of 9 Old 06-06-2010, 12:36 PM Thread Starter
xjjeepinmatt
xjjeepinmatt's Avatar
I was sitting at stop sign today with my a/c on and suddenly i heard a hissing sound and smoke came through my vents and some out my hood. Then the a/c got warm and smelt funny. Everything else is running fine, but apparently something blew up or messed up on my a/c unit. Any help on what it is would be greatful?
thanks,
matt
Spc US Army
1990 Jeep Cherokee Full Traction 6 inch longarm. 305 BFG Km2's. Front and rear detriots. 4.10 Gears!
1999 Grand Cherokee 4x4 Daily Driver!
1992 XJ 6 inches lift 35s d44 SOLD!!! 88 XJ 4.5 Inches of lift 33's SOLD!!
xjjeepinmatt is offline
post #2 of 9 Old 06-06-2010, 04:07 PM
smuggler
You sprung a leak and de-pressurized your A/C system. If you can't find it by looking you'll need to take it in to have it shot with dye. Hopefully you'll only need to replace a fitting or line, and not the whole system.
smuggler is offline
post #3 of 9 Old 06-06-2010, 04:27 PM Thread Starter
xjjeepinmatt
thanks i will try to find the leak if not i will take it in.
Thanks again
post #4 of 9 Old 06-06-2010, 04:55 PM
88yjproject
Shouldn't be too hard to find if it did it at a stop light. SHould be a pretty big hole.
88yjproject is offline
post #5 of 9 Old 06-06-2010, 05:23 PM Thread Starter
xjjeepinmatt
well i checked for leaks under hood all i found was some refrigirant/coolant underneath the accumulator (black oval shaped thing i think it is lol) i pulled the line off the top of the accumulator and the green o ring looks really worn out? think that is my problem? if thats the problem or if i ever find the leak, do i just recharge the system with one of those kits from o'reillys or autozone??
thanks for all the help
post #6 of 9 Old 06-06-2010, 05:25 PM
88yjproject
Could be the o-ring or it could be the accumulator.
post #7 of 9 Old 06-07-2010, 10:27 AM
jclaudii
no...once the system is opened up you'll have to put it under a vacuum to remove all the air and moisture from the system. This is also a quick "test" to make sure there are no more leaks. when you removed the line was there any pressure?
If you own an air compressor you can buy a tool that attaches to your air hose that will pull a vacuum. Some manifold gauges do come in handy so you know if you system is leaking still or not and how much refrigerant to add back to the system.
jclaudii is offline
post #8 of 9 Old 06-07-2010, 11:39 AM
classicmetalman
Definitely pull a vacuum. $130.00 at Harbor Freight n you can pick up a A/C gauge set n vacuum pump.
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #9 of 9 Old 06-08-2010, 10:17 AM
twmart
As stated above make sure you pull a vaccum. I just did this last weekend on my 94, here are the steps from my manual.
1) Pull a vaccum takes about 2-3 min to get down continue to pull vaccum for 10 min.
2) turn off vaccum pump and left sit for at list 5 min (I waited 10) make sure your vaccum stays and does not drop, this would indicate a leak in the system.
3) If everything is good the pull the vaccum for an additional 10 to 15 min.
4) Add your can of R-134a OIL first (10.5 oz can = 8.5oz oil and 2oz freon)
5) Add your freon (ours took 1 can of pag oil and 2 cans freon)
6) Make sure to watch your gauges as you are changing you do not want to over charge.
You may need to bypass the low pressure clutch cycle switch to keep the compressor turning.
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Trailer Hitch swap from Cherokee to Grand Cherokee hitchikerjoe ZJ Grand Cherokee Forum 4 09-29-2008 05:02 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
