A/C compressor turns on and off - JeepForum.com
post #1 of 6 Old 07-01-2012, 05:47 PM Thread Starter
pinky2252s
EDIT: Not that any one cares but I fixed it (I hope). I found out that the A/C compressor will turn on and off when its low on R134. So I hooked up the gauge and the can and when the gauge went as high as it would go before dropping, I would squeeze the trigger and let a little in. I did that about three times and then the A/C compressor stopped turning on and off! Then it gave me an actual reading, it was 15 PSI=BAD. So I filled it to 50ish (Thats what the can said for the ambient temp). And now it blows freezing cold. Success! Now if it gets warmer, I know I have a leak. I have a friend who has one of those sniffer things for R134, and I can use that.
I also read that is not the EVAP core that actually causes the leak, its the seal on the clutch for the A/C compressor. That'll be the first place I look.
I think I found the problem to my A/C not being very cold.
I found an A/C gauge in my garage, so I connected it to the port. It read in the right range for the ambient temperature, but once it got up to that point, the gauge needle drops to 0 and I hear the compressor "CLICK" and then the gauge slowly rises up again, then the compressor clicks, then the pressure falls, and repeats. It does this with the gauge on the port or off the port.
Its not supposed to do this right? Its a pretty loud click too.
Any thoughts?
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #2 of 6 Old 06-05-2013, 06:53 PM
PAJeepLover
I care. Thanks for posting. My jeep is doing the exact same and now I know how to fix it
2008 JK Red Rock X
It's A Jeep Thing
PAJeepLover is offline
post #3 of 6 Old 06-05-2013, 07:06 PM
maloj2003wj
2006 WK
thanks, that is definitely useful info.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #4 of 6 Old 06-09-2013, 06:29 PM Thread Starter
pinky2252s
Just an update, the A/C still blows ice cold about a year later.
Is it broken?
post #5 of 6 Old 06-09-2013, 06:39 PM
Jaysun1994
my jeep is doing the same thing thank you
Jaysun1994 is offline
post #6 of 6 Old 07-01-2013, 01:24 PM
ChrisWK
2005 WK
Unhappy Ac cold some times
I was looking at ac compressor on my jeep and it is cycling on and off should it not be doing that?
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline
A/C turns on but no air from vents pichi WJ Grand Cherokee Forum 10 08-05-2012 01:50 PM
4.7V8 Turns but won't start right away ElkGroveJeeper WJ Grand Cherokee Forum 34 07-08-2012 06:07 AM
Grinding on turns jimdonut WJ Grand Cherokee Forum 4 12-02-2011 01:48 PM
something not engaging around turns nick0413 WJ Grand Cherokee Forum 5 09-04-2011 06:17 PM
rattle on right turns mattjay WJ Grand Cherokee Forum 0 02-21-2011 02:34 AM
