a/c blend door problems, need help - JeepForum.com
post #1 of 11 Old 08-13-2010, 09:40 PM Thread Starter
gsxrJ
I just got my 2000gc limited back on the road yesterday (spun rod bearings) and everything was fine until tonight. I had the jeep idling and all of a sudden the passenger side vents start blowing out really hot air. Driver side was fine and the a/c stayed cold but I cant get the passenger side to stop with the hot air. I also live in South Carolina so its like 110 degrees or so and I cant get the heat to cut off so any help will be greatly appreciated.
gsxrJ is offline
post #2 of 11 Old 08-14-2010, 08:14 AM
Johannmn
How many miles are on your WJ and have you ever replaced the HVAC blend doors? Sounds like you are about to spend some quality time with your jeep replacing them if you have dual climate control. Been there... done that!
Johannmn is offline
post #3 of 11 Old 08-14-2010, 10:33 AM
ljhopp
Go to heater treater website they will show exactly how to fix this problem.
ljhopp is offline
post #4 of 11 Old 08-14-2010, 12:30 PM
oldfamilyguy
I used the "blen dor" kit, find it on ebay. It seems really well made and simple to intall. Tape over the passenger side outlets for now to keep cool until you can fix it.
oldfamilyguy is offline
post #5 of 11 Old 08-14-2010, 11:48 PM
straty1987
first see what codes you get.
just go to Jeep Grand Cherokee WK - Climate controls and follow teh steps under AZC self-diagnostic mode:
i did the threw the dash fix and hears my write up with the how to. http://www.jeepforum.com/forum/f13/d...p-pics-884932/
simple, under and hour, and a bit over $200 if only the door is broken
straty1987 is offline
post #6 of 11 Old 08-15-2010, 07:11 AM
curt93t/t
Had the same problem on my wifes 2000 Jeep. Go to Blendorstore.com and buy the kit for $135 and you'll fix your problem. Go ahead and get the recirc door for $45 while you're doing it. I won't lie, it sucks taking out the dash and probably even more putting it back together again. You're gonna need to get the A/C drained obviously. You can do this all yourself or pay an extra$800-$1,000 to have the dealer do it. You tube grand cherokee dash removal, it might help.
curt93t/t is offline
post #7 of 11 Old 08-15-2010, 04:21 PM
straty1987
they now have the dual control fix that you do not have to take apart the entire dash, posted how to above
post #8 of 11 Old 08-15-2010, 06:07 PM
Mr_Grumpy
Theres no link on how to do the fix btw ,incase u didnt realise and forgot to put it in
Mr_Grumpy is offline
post #9 of 11 Old 08-15-2010, 07:19 PM
Twospeed
Mine acts that way sometimes even though I've replaced the blend doors, actuator and head unit. Particularly after I've disconnected the battery for some reason. Try initializing a recalibration of the doors.
Twospeed is offline
post #10 of 11 Old 08-15-2010, 07:24 PM
straty1987
fixed it
post #11 of 11 Old 08-17-2010, 09:17 PM Thread Starter
gsxrJ
thanks for all the info, I will try anything to keep from having to take the dash out.
but now its back acting right, a/c is coming out of all the dash vents. anyway.....
gsxrJ is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 07:12 PM
Another HVAC Blend Door problem. Twospeed WJ Grand Cherokee Forum 0 06-30-2010 09:09 PM
1999 WJ AC problems Blend Door esco1402 WJ Grand Cherokee Forum 0 04-11-2010 06:26 PM
Temp. Blend Door Fix seve7 WJ Grand Cherokee Forum 9 03-03-2010 09:29 AM
Help me find this blend door thread!! CrazyWalnut13 WJ Grand Cherokee Forum 4 02-12-2009 01:36 PM
