Bypass hose from water pump - JeepForum.com
post #1 of 8 Old 08-03-2012, 08:37 PM Thread Starter
elcorvino
2003 WJ
I called the local auto zone - they did not have this part in stock and said none of their stores carried it. Is this a piece I would have to get directly from the dealer? Any idea on price?
It's the metal hose that comes directly off the water pump to the heater.
elcorvino is offline
post #2 of 8 Old 08-03-2012, 08:59 PM
roadcrew
Does it leak?
If not, pull it off, hit it with a steel brush, paint it and replace.
If it leaks, hit up a junk yard, then follow above.
roadcrew is offline
post #3 of 8 Old 08-03-2012, 09:05 PM
qualmanj
If your that worried about it Orilleys has them. There made by Doorman http://www.oreillyauto.com/site/c/de...6484&ppt=C0331
qualmanj is offline
post #4 of 8 Old 08-03-2012, 09:09 PM Thread Starter
elcorvino
2003 WJ
Originally Posted by roadcrew
Does it leak?
It's so old and nasty - its legit stuck in there. I put the pump in a press and tried to turn it with a pipe wrench. I weigh 230 and bench 335 and couldn't get it to budge. I figured if it was cheap enough i would get a new one.
post #5 of 8 Old 08-03-2012, 09:10 PM Thread Starter
elcorvino
2003 WJ
No Oriellys down here in south Florida. We have every other parts stores. Thank you for the link. I'll check around in the AM!
post #6 of 8 Old 08-03-2012, 10:22 PM
qualmanj
Well anybody who sells doorman parts should be able to get that part number. Check with whom ever sells it.
qualmanj is offline
post #7 of 8 Old 08-03-2012, 10:28 PM
Cirruslydakota
Use some heat, it'll come right out like butter. You can get it from the dealer or from rock auto ($8-10 I think). If you can get it out id clean it up, paint it and use it.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is online now
post #8 of 8 Old 08-03-2012, 10:59 PM Thread Starter
elcorvino
2003 WJ
You guys were right. I searched by part number and the guy on the phone just didn't look it up right. Advanced auto and autozone both have it. Only $10. It's kind of dingy looking and rusting. Kinda feel like for the $10 I ought to just replace the piece. I hate cutting corners especially on cheap parts.
