Bump steer,IRO trackbar question - JeepForum.com
post #1 of 5 Old 10-27-2013, 01:45 PM Thread Starter
w33mud
2006 WK
Fitted the trackbar & adjusted the length so the axle is centered under the body,I now have bump steer which pulls to the left then centeres again straight away.I removed the trackbar drop bracket which came with the lift but have left in place the drop pitman arm,so my question is the bump steer caused by the bars not being parallel when the suspension compresses or can it be sorted by lengthening or shortening the track bar?
All the front end parts are new( had d/w) thanks.
w33mud is offline
post #2 of 5 Old 10-27-2013, 01:52 PM
texlurch
yep. You need either both the drop bracket and pitman, or neither.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #3 of 5 Old 10-27-2013, 02:47 PM
MuddyWJ
You don't need either bracket or arm with the adjustable TB. Take both off and just use the TB.
MuddyWJ is offline
post #4 of 5 Old 10-28-2013, 03:06 AM Thread Starter
w33mud
2006 WK
Thanks,will put the original arm back on aswell,was I right setting the track bar length to center the axle?thanks guys.
w33mud is offline
post #5 of 5 Old 10-28-2013, 03:38 AM
texlurch
yep, center the axle to the vehicle
texlurch is offline
