Budget boost on top of 2" suspensikn lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Budget boost on top of 2" suspensikn lift?
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 09-11-2014, 09:22 AM   #1
bwiygul
Just curious about any intel and pics of 2" suspension with a 2" bb. I'm thinking about adding the bb to my spring lift. Pluses or minuses? Thanks.
bwiygul is offline   Reply With Quote Quick reply to this message
Unread 09-11-2014, 09:24 AM   #2
Jeeples
Just go for broke, 2" BB on top of 4" springs.
#YOLO!
His: '00 WJ 4.7 Limited- stock
Hers: '03 WJ 4.7 V8- IRO 3", 245/75/16 Duratracs
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 09-11-2014, 09:33 AM   #3
ChrisHager
ChrisHager's Avatar
Positives: You'll have a 4 inch lift.
Negatives: You'll need everything that's necessary for a 4" lift.
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 09-11-2014, 09:35 AM   #4
bwiygul
Lol!! Right! I don't want to break the bank. Just fit these tires. I've got toyos now but pretty much stole the silent armors on jk rims. They're 255's though. Everybody says they won't fit even remotely well even with 2". So with 4 I should be good and not have to mess with more suspension stuff. Just sway links and I think my shocks are already covered.
Anybody done it and/or have pics?
Unread 09-11-2014, 09:38 AM   #5
ChrisHager
ChrisHager's Avatar
What size are they (255/75R16)?
A 4" lift will take much more than new sway bar end links.
Short list: shocks, adjustable control arms or long arms, adjustable track bar, possibly new drive shaft.
Hers: 2000 TJ
WJ Torque Specs
Unread 09-11-2014, 09:52 AM   #6
bwiygul
I'm not talking about a 4" suspension lift. I'm talking a 2" suspension ( which I already have) and ADDING a 2" budget boost to it. I think I forgot to mention that I already have adj track bar and lower control arms. And I'm pretty sure my 5100's are 2-4" lift so I don't have to mess with them either.
Tires are 255/75/17 Goodyear silent armors
Unread 09-11-2014, 09:57 AM   #7
ChrisHager
ChrisHager's Avatar
Stacking 2" spacers on 2" springs is the same as a 4" suspension lift using 4" springs. Both equate to 4" of overall suspension lift no matter which way you slice it.
Hers: 2000 TJ
WJ Torque Specs
Unread 09-11-2014, 10:06 AM   #8
bwiygul
Ahh. I guess I was still thinking bb = body lift. I see my flaw. So if I already have track bar and adj lowers will I need a new driveshaft at 4"? Should just need what I have plus sway links no? And adjustments to current parts?
Unread 09-11-2014, 10:32 AM   #9
ChrisHager
ChrisHager's Avatar
You'll want all adjustable arms at minimum. These will need adjusted to set your caster. You'll need to adjust your track bar to center your axle as well. The front and rear sway bar links and bump stops will need extended and your drive shaft may need replaced depending on what type you have.
At 4", I'd also set aside a decent chunk of change to deal with the possibility of death wobble. Remember, worn suspension components are more noticeable the higher you lift.
Hers: 2000 TJ
WJ Torque Specs
Unread 09-11-2014, 11:13 AM   #10
bwiygul
Well I just did the 2" less than a year ago and did all tre's and the jks hd track bar and rc adj lca's. So hopefully I won't need anything more than adjustable uca's and sway links. And bump stops.
