budget boost=clicking noise? - JeepForum.com
post #1 of 16 Old 07-16-2013, 11:57 PM Thread Starter
norrod414
I recently added a budget boost to my 2000 GCL and I had no trouble until I pulled my 17 ft boat to the lake then got home unhooked it and started hearing a aggravating clicking noise sounded like a u joint to me but they're all tight and leave no signs of rubbing the yolks....any help?
norrod414 is offline
post #2 of 16 Old 07-18-2013, 08:20 PM
Cebby
Front Driveshaft Rzeppa Joint at the Transfer Case
Budget Boost accelerated the demise of mine. It was probably already on it's way out.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Clayton LA Front/Rear | IRO 3" Springs + 3/4" KOR | Bilstein Shocks | JKS Discos/Trackbar/Draglink & Tierod | Dual KOR Stabs | Spidertrax Spacers | 265/70R17 Duratrac's on JK 17's | Black Magic Brakes w/Centric Rotors | Akebono Calipers | Griffin Rad | K&N Drop in | Magnaflow Cat & Muffler shorty setup | Diehard Platinum (Odyssey) | RB1-NAV-Sirius-Chg-iPod | OEM Tow Hooks F/R
Cebby is offline
post #3 of 16 Old 07-18-2013, 08:57 PM
CrazyWalnut13
Where's the sound coming from? Does the clicking noise get louder/faster when you speed up or turn?
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #4 of 16 Old 07-18-2013, 09:24 PM
LarryDallas
Did you change shocks or unbolt the sway bars during install? Retighten all those if so. A lot of people have loose shocks, but I had a loose end link that clicked. That is the first place to look before replacing bushings or worse.
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline
post #5 of 16 Old 07-20-2013, 07:30 PM Thread Starter
norrod414
Yes it does sound like the transfer to me or really close to it...it does however speed up or slow down with the speed of the vehicle. It doesn't do it all the time just every now and then and it has me confused. Should it not do it all the time?
post #6 of 16 Old 07-20-2013, 07:36 PM
tkcarp01
Do you notice it when driving straight, or turning, or both?
tkcarp01 is offline
post #7 of 16 Old 07-20-2013, 07:49 PM Thread Starter
norrod414
Driving strait and turning to the left. It doesn't do it when turning right...and again its only doing it partial time. I even put the transfer in neutral and put the tranny in neutral go in down a hill and it still done the clicking and when I started back up the hill it stopped
post #8 of 16 Old 07-20-2013, 08:05 PM
tkcarp01
Hmm... Have you checked the CV joint boots on your front axles? If one of them has a tear... Your joint may be going out.
tkcarp01 is offline
post #9 of 16 Old 07-20-2013, 08:23 PM Thread Starter
norrod414
Yeah I checked everything the other day and even took to a local mechanic and he couldn't find a single thing wrong with it checked everything pulled all the drive lines and checked all the case fluids and everything checked out but then again he's not a full time jeep mechanic I think its something simple that I'm worrying about
post #10 of 16 Old 07-20-2013, 08:35 PM
tkcarp01
You could always use the tried and true method of drive it until something breaks. Then you'll know. :-D
tkcarp01 is offline
post #11 of 16 Old 07-20-2013, 10:33 PM
Cebby
How many miles on your Jeep?
Cebby is offline
post #12 of 16 Old 07-21-2013, 12:24 AM Thread Starter
norrod414
130,000 miles I've had it roughly a couple months haven't done anything besides the Bb a brush guard and a light bar on the roof and I'm sure that didn't cause a noise haha..I've read on here that if the transfer or front end gets low of fluid it could cause the "noise" they also said there's an additive of some sort that it needed too. But then again if my mechanic thourghly then he should have seen either or being low?
post #13 of 16 Old 07-21-2013, 07:28 AM
tkcarp01
Yes.. Your x-case needs Mopar 247 fluid ONLY. Your diffs have a few options... I know a lot of guys on here use the Redline 75w-140, even more use the Mopar spec with friction modifier. I use the Royal Purple with the modifier already added. It'd be worth a call to the Mechanic to make sure he didn't use regular ATF+4 in the x-case, and put the correct fluid in the diffs.
tkcarp01 is offline
post #14 of 16 Old 07-21-2013, 09:03 AM
alfaitalia
Or Petronas Arbor or Mobil 424....all now factory approved.....and quite a bit cheaper...at least it is in the UK!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #15 of 16 Old 07-21-2013, 02:19 PM
tkcarp01
... Or that stuffs, depending on who you ask.
tkcarp01 is offline
