Brush Guard Mounting Hardware - Page 3 - JeepForum.com
post #31 of 64 Old 07-26-2013, 04:28 PM
Aaron00
Originally Posted by 99WJ539918
Okay, I thought I only saw two bolts down there. Good to know I'm not going crazy.
I'm about to go out now and start grinding on the old brush guard. I hope this rust lifts.
Good luck I hope it dose to! Post up photos when your done!
Aaron00 is offline
post #32 of 64 Old 07-26-2013, 07:17 PM Thread Starter
99WJ539918
Damn, sanding it down was not fun. I had plans to go down to the bare metal all around, but just taking the rust off was harder than I imagined. I removed the headlight grills and wiped them down with a foam spray, then used a scotch brite pad to scuff them up, and then wiped them down real good with Acetone. Then I sprayed them with the spray on bedliner. I used two coats and let the first coat dry for five minutes. I want to see how they look in the morning before I paint the brush guard. This way I'll know if I have to take all of the crappy powdercoating off or if I can paint over it. The spray on bedliner itself didn't really spray as evenly as I hoped, but since the finish is not smooth it shouldn't be an issue. I'll post pictures of the before, middle, and after when I'm done with everything. It should be around next Tuesday, I can only do a little bit at a time.
Build Thread
99WJ539918 is offline
post #33 of 64 Old 07-26-2013, 08:04 PM
Aaron00
Wow sounds tough!
Aaron00 is offline
post #34 of 64 Old 07-27-2013, 08:24 AM Thread Starter
99WJ539918
The headlight grills came out great, so I just got done scuffing the rest of the grill guard, wiping it down, and then putting the first coat on. I'll go out in an hour to do the second coat, and an hour after that I'll do the touch up. The spray on cans are crap, they don't spray evenly at all. I'm going to use two cans on just the brush guard. Once the can gets half full the spray becomes really uneven. Oh well, I guess it's a good thing that I got two cans.
Build Thread
post #35 of 64 Old 07-27-2013, 10:54 AM
fosterjd79
Are you shaking it every minute or so? The grit will settle quickly and cause it to spray uneven.
fosterjd79 is offline
post #36 of 64 Old 07-27-2013, 05:51 PM
Jrboarder27
Originally Posted by 99WJ539918 View Post
Is Manik out of business? They're who made the brush guard. Anyway, I found a place that sells the bracket hardware. No need for the pictures. Thanks anyway, Aaron00.
Do they have an online store? I need some hats way too
Jrboarder27 is offline
post #37 of 64 Old 07-27-2013, 06:49 PM Thread Starter
99WJ539918
I would shake it for a minute for the first spray and then about twenty to thirty seconds every half minute to minute or so. I went through two bottles and I need a third for touch ups. The first two bottles aren't empty, but the spray is too uneven and I don't want it to look like crap.
Build Thread
post #38 of 64 Old 07-27-2013, 06:49 PM Thread Starter
99WJ539918
An online store for where I got the brackets and hardware? If so, I posted it earlier.
Build Thread
post #39 of 64 Old 07-28-2013, 11:07 AM Thread Starter
99WJ539918
Just got done touching up the grill guard. It came out pretty nicely. I recommend anyone with a rusted grill guard to do this. Once it dries I'll take some pictures. You can still see it's not that smooth where the major rust spots were, but it looks a lot better.
Build Thread
post #40 of 64 Old 07-28-2013, 11:19 AM
Aaron00
Looking forward I bet it looks good!
Aaron00 is offline
post #41 of 64 Old 08-03-2013, 08:09 AM Thread Starter
99WJ539918
Well, got the brackets in and they won't work with the Manik brush guard. I have two options: Sell the Manik and buy a brush guard from the company I bought the plates from or keep the Manik and just make plates. I'll probably just make some brackets...
Build Thread
post #42 of 64 Old 08-03-2013, 08:46 AM
Aaron00
You want a photo of the ones I made? Or just try it yourself
Aaron00 is offline
post #43 of 64 Old 08-03-2013, 09:30 AM Thread Starter
99WJ539918
Sure, anything you got would help, bro.
Build Thread
post #44 of 64 Old 08-03-2013, 09:36 AM
Aaron00
Here's some
Aaron00 is offline
post #45 of 64 Old 08-03-2013, 09:44 AM Thread Starter
99WJ539918
Nice, thanks.
Build Thread
