Broken Track Bar Bolt - JeepForum.com
post #1 of 15 Old 03-07-2013, 10:39 AM Thread Starter
Dazed8
So here's my dilemma, Ive been installing a 3" lift on my wj and now I'm stuck since I broke a bolt.. The lower one on the track bar. It looks like a real pain to get out, should I try to use an easy out or just get it towed to a shop to get it removed? Has anyone else broke this bolt before?
Also, where can I get a replacement bolt for it or what type is it from the factory? I'm putting in a JKS adjustable track bar if that makes any difference, I know that the stock bolt works but I don't know where to get a new one or what to ask for.
Any help would be greatly appreciated!
Dazed8 is offline
post #2 of 15 Old 03-07-2013, 10:55 AM
briandor
Just went through this yesterday. You think the lower one is bad try the upper one. You probably won't get that bolt out but that's ok. The other side of that bracket is just a nut welded on. So what you need to do is knock that nut off. I didn't have any room to really swing a hammer on the top one so what I did was took my Dremel and used a metal cutting disk and cut as far down into the nut on the back side as I could. Then I took a cold chisel and small sledge hammer and kept wacking it until the nut broke loose. From there it's easy. Just go to Lowes and get a M10x1.5x30 grade 8 hex bolt and nut and put that in to replace what you broke and the nut you removed.
I tried to remove the bolt from the existing nut and that was pretty much impossible. This way is much easier.
briandor is offline
post #3 of 15 Old 03-08-2013, 08:18 AM
3JsWJ
Double check that size. I think it is M12-1.75 x 80mm. Too small of a bolt will allow the track bar to move.
04 WJ-4.7, 242HD, JK D44, JK HP30, 4" IRO, LSR Bumper, Warn M8000, 33" MTZ
03 WJ-SOLD
3JsWJ is offline
post #4 of 15 Old 03-08-2013, 08:31 AM
Merc1973
Yep. But make sure the shank does not taper.
You can get one from the dealer for ~$7
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #5 of 15 Old 03-08-2013, 08:43 AM
briandor
Yes. You're right. When I first saw the picture I thought it was the rear sway bar. Oops. Well maybe the Dremel advise works for this too.
briandor is offline
post #6 of 15 Old 03-08-2013, 08:49 AM
mtb_crzd47
Could you stick a drift punch or whatever it's called and smack it out with a hammer?
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
post #7 of 15 Old 03-08-2013, 10:40 AM
shockracer
Well you have to cut that nut off you may as well order KOR duro bushings and bolt and sleeve kit for the track bar.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #8 of 15 Old 03-08-2013, 12:57 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I broke that bolt too, ended up taking the axle out and running it to a local machine shop. The guy actually welded a nut to the broken bolt through that gap and was able to work it out with some heat. It was pretty impressive. And he only charged me $10 lol
~James
ezflip is offline
post #9 of 15 Old 11-17-2013, 05:23 PM
PetrolPete
Just broke the damn bolt off. Going to attempt to punch it out tomorrow or cut the nut off with a grinder.
PetrolPete is offline
post #10 of 15 Old 11-18-2013, 10:45 PM
PetrolPete
Got the nut and bolt off with an air chisel.
post #11 of 15 Old 11-19-2013, 09:23 AM
Jeeples
Jeeples's Avatar
I hope all you guys that have had to deal with this broken track bar bolt are doing yourself a huge favor for future disassembly by using anti-seize on the new bolt.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #12 of 15 Old 05-05-2015, 01:40 PM
cgmoss121
I just broke the same bolt... My idea was the same.. Break the nut off the frame.. We will see how it goes. Does anyone have any suggestions on the best course of action for this?
cgmoss121 is offline
post #13 of 15 Old 05-05-2015, 04:49 PM
befirst
Like PetroPete, I used an air chisel with a punch style bit. If you use it through the hole and hit the edges of the nut it will pop right off. It is only spot welded in 3 little spots.
befirst is offline
post #14 of 15 Old 05-05-2015, 07:56 PM
Hlude1
I also had that bolt break. Went at it with a punch going thru the bolt hole. Took a few hits but was able to break the welds that way. Now fishing a nut back in there and holding it to get the bolt started took alittle time. Nothing alittle electrical tape and a open end wrench couldn't handle though.
Hlude1 is offline
post #15 of 15 Old 05-06-2015, 05:23 PM
befirst
I welded a metal tab on the nut so I could hold it with my fingers. Then the tab held it while I tightened it so I didnt need a wrench.
befirst is offline
