Broken Sway Bar mount bolts - JeepForum.com
post #1 of 8 Old 11-02-2011, 06:54 PM Thread Starter
2000wreckedwj
On the rear end of my wj where the rear sway bar mounts to the axle housing, The four bolts that hold it on broke off. I believe that they were cross threaded too. Not enough is sticking out the get hold of with a pair of pliers. I have already broke off one drill bit in one of the bolts trying to get it out. Any other tips or thoughts on how to remove them? Thanks
2000wreckedwj is offline
post #2 of 8 Old 11-02-2011, 08:22 PM
pjkatz04
Bolt extractor.
2002 4.7, Selec-Trac, K&N FIPK II, JetChip Stage 1.
pjkatz04 is offline
post #3 of 8 Old 11-02-2011, 08:22 PM
pjkatz04
Also if it's real bad bring it to a machine shop and they can weld a nut to the bolt and then use a rachet to back it out. As a last resort plan..
pjkatz04 is offline
post #4 of 8 Old 11-02-2011, 08:31 PM
BreadsWJ
Heat 'em up from the other end and try to grab pliers to twist and unscrew out the back way.
Worked for me when I busted one...
---CHECK OUT MY WJ PARTS FOR SALE THREADS ---
"He who seeks knowledge, begins with humbleness" - Anon
BreadsWJ is offline
post #5 of 8 Old 11-03-2011, 05:38 AM Thread Starter
2000wreckedwj
I can weld anything to whats left of the bolt. They are recessed into the nut where they broke. I am going to get the tanks on my torches filled today and try to heat the nut up. Worst case I guess i will melt the bolt and nut off then put a new nut and bolt in
post #6 of 8 Old 11-03-2011, 06:07 AM
hammerz71
Ain't had a broken bolt or screw yet I couldn't get out with a set of Grab-Its.
http://www.amazon.com/Alden-8440P-Grabit-Damaged-Extractor/dp/B001A4CWHO
I know Lowes sells them, or at least did at one time...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #7 of 8 Old 11-03-2011, 07:42 AM
3JsWJ
That's what I had to do on one that was froze up pretty bad. Just torched the whole nut off and used a new one.
3JsWJ is offline
post #8 of 8 Old 11-03-2011, 11:14 AM
roadcrew
I had one break too. No way to weld something to it,as it broke below flush.
Took a torch to it, got other real hot then hit the oxygen, blew it right out of there. Then used a wing nut and a new bolt.
roadcrew is offline
Five of ten bolts broken Knoxes WJ Grand Cherokee Forum 3 08-03-2011 08:19 AM
Sway Bar bolts need to be tight? flyboy14295 WJ Grand Cherokee Forum 1 04-08-2011 03:30 PM
broken bump stop bolts overlandHO WJ Grand Cherokee Forum 1 08-12-2010 03:26 PM
Help! Dropping WJ fuel tank- broken bolts! askoop WJ Grand Cherokee Forum 4 07-17-2010 06:29 PM
