Brakes smoking - JeepForum.com
post #1 of 12 Old 07-13-2013, 09:42 AM Thread Starter
wyattwj123
Brakes smoking
Hey guys about a week ago my driver side brakes were rubbing and so I took it apart and realized that one of the caliper pistons were broken so I replaced the caliper on the driver And the pads on both sides now a week later it seems like the passenger side is smoking after driving? Could it be something else on the brakes thank you?!
wyattwj123 is offline
post #2 of 12 Old 07-13-2013, 10:30 AM Thread Starter
wyattwj123
I guess ill just take the other caliper off and check it out
post #3 of 12 Old 07-13-2013, 11:16 AM
Stimmel
Replace the hoses when you do it, I had same issues replaced calipers and hoses good as new now!
Stimmel is offline
post #4 of 12 Old 07-13-2013, 12:21 PM Thread Starter
wyattwj123
How much did the hose run you?!
post #5 of 12 Old 07-13-2013, 04:40 PM
CopperDeer
Could be "unbalanced" now making the pass one do all the work, I try to stick to replacing everything on brakes in pairs. If the driver's side caliper was bad theres a good chance the pass one has problems. Or the pass caliper could have a seized guide pin causing it to stick, or problems with the hoses like mentioned. Try bleeding both calipers just to be sure there isn't any air / difference in pressure in the lines and check out the condition of the pass caliper.
CopperDeer is offline
post #6 of 12 Old 07-14-2013, 07:14 AM
4Tom
I too replace in pairs to avoid this problem
I would hazard a guess the passenger side caliper piston is sticking.
For some reason teves calipers seem more prone to develop issues just after new pads are fitted.
WJ 2001 3.1TD
Tom
4Tom is offline
post #7 of 12 Old 07-14-2013, 07:41 AM
CarlJH
2003 WJ
x2^^
just after i had the rears apart to check the axle seals were ok after having new bearings
and seals fitted and lube the slide pins, the left rear seized up.
I think its partly down to the inner pad being clipped into the piston so it can't move about like
the outer one does.
CarlJH is online now
post #8 of 12 Old 07-14-2013, 10:14 AM Thread Starter
wyattwj123
I'm going to get new rotors and a pads caliper today and see what happens thank guys
post #9 of 12 Old 07-16-2013, 07:13 PM Thread Starter
wyattwj123
Replaced rotors and caliper works great and no 50 mph wobble
post #10 of 12 Old 07-16-2013, 08:01 PM
4Tom
Great satisfaction in DIY
WJ 2001 3.1TD
Tom
4Tom is offline
post #11 of 12 Old 07-17-2013, 12:56 AM
alfaitalia
Absolutely!........Especially if you are too poor to pay 100 an hour in labour! That's the main reason I learned to spanner my motors. It's amazing what you can learn if you don't have a choice. Nothing I would not do myself these days. Only time my Jeep goes to a workshop is for the mot (safey check)......although I might have to concede defeat on my rear pinion seal...just can't shift the nut!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #12 of 12 Old 07-17-2013, 06:23 AM
4Tom
If you had a good compressor and air ratchet with big socket it might shock it off. I never done mine so not sure whats involved.
https://www.youtube.com/watch?v=Z0zz...e_gdata_player
The video makes it look so easy.
Never my experience anytime I got to remove bolts. I had a horrible time removing the caliper bracket bolts and all the videos on youtube made me think I was doing something wrong. Ha ha
WJ 2001 3.1TD
Tom
4Tom is offline
