Brakes pulsing - JeepForum.com
post #1 of 3 Old 04-21-2004, 11:16 AM Thread Starter
Bill08690
Brakes pulsing
My '02 Overland 15K miles has a spot on the front rotors that grabs when the brakes are applied, causing a sensation of pulsing of the brakes. No pedal or steering wheel vibration is felt. My brake shop said that my rotors were probably rusted one time and that the spot that was protected from the rust is working better than the rest of the rotor. I can see the outline of the brake pad on one of my front rotors. Question is what to do about this. My brake shop wants $85.00 to resurface the rotors on the vehicle.
Will this problem correct itself with more use of the brakes? Since it's used for around town travel it does not get many miles of use.
Bill08690 is offline
post #2 of 3 Old 04-21-2004, 11:54 AM
Astorm
The rotors are most likely warped. Grand's will do that every 15,000 or so. You can go to a local parts store, and buy brand new rotors for about $40 each. I had the same problem, and this solved my problem.
Andy
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline
post #3 of 3 Old 04-21-2004, 02:02 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Bill:
Look in the FAQ section (third row from the top of this forum) there is a post about your problem.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
Deep pulsing droning noise on highway... a_kraker99 WK Grand Cherokee & XK Commander Forum 13 12-16-2008 09:43 PM
Slamed on brakes now no brakes? 94ZJLaredo ZJ Grand Cherokee Forum 7 09-15-2008 09:07 PM
Upgrade WK brakes to SRT-8 brakes? Gannet WK Grand Cherokee & XK Commander Forum 3 12-11-2007 08:43 PM
Lurching/Pulsing 96 Grand Cherokee tdk ZJ Grand Cherokee Forum 4 06-12-2007 04:25 PM
93 GRAND Cherokee NO SPARK NO PULSING OF INJECTORS JERRYT30 ZJ Grand Cherokee Forum 10 06-15-2006 01:55 PM
