Brake Rotors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Brake Rotors
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 06-25-2003, 08:24 AM   #1
vngdh
Question Brake Rotors
Well Im at the point where I must order a pair of front brake rotors (after some thought of upgrading to slotted rotors I decided to purchase basic Bremos).
I have never done a rotor replacement. Could someone who has done this on a 2000 drop me a checklist/repair guide pics would be nice (also... does Chilton's or Hayes have a Repair Book out yet?)
TIA -
Dan, shuddering to a stop
2000 WJ Limited: V8, QuadraTrac-II, Black with Camel leather.
Every option except 10 disk CD Changer.
Mods: K&N GenII Ram Air, Helix Powertower
Future Mods: HID level I High & Low beam, Larger Rims (undecided), Kenne Bell Supercharger (screw-type) with water injection kit (to prevent pre-detonation).
vngdh is offline   Reply With Quote
Unread 06-25-2003, 10:26 AM   #2
PDshooter
Yep! did mine about 3 weeks ago. Replaced all 4 and pads. NAPA has what you need. Picked-up El-Cheapo brand and pads work "GREAT" all for about $140 bucks!
Hard part is getting the old stuff off (Rotors) WD-40 and a BFH
PDshooter is offline   Reply With Quote
Unread 06-25-2003, 11:58 AM   #3
Lodgepole
brakes
They go back just like they come off. Once you get the caliper off, the rotors should slide right off but they will probably be rusted in place. Be sure to clean and lube the caliper guides. You will need a big C clamp or other to compress the caliper pistons back in so the new pads will fit in place. This will send fluid back to the master cylinder and it could run over so watch for this.
Lodgepole
Lodgepole is offline   Reply With Quote
Unread 06-25-2003, 01:34 PM   #4
vngdh
Exclamation Concerns regarding air in brake lines
Another newbie question...
Whats the possibility of accidently allowing air into the brakelines?
Tips to prevent this?
thanks again,
Dan
Unread 06-25-2003, 02:19 PM   #5
Lodgepole
air
I have done a lot of disc brakes and have never gotten air in lines. Just pull off the pads and compress the piston all the way in and you will be ok. Drum brakes are another matter, you will probably get air in the wheel cylinder and have to bleed them. The first brakes I did, I was 16. Did them on a "46 Olds. Took the linings off the shoes and re-riveted new ones on. A real learning experience.
Lodgepole
Unread 06-25-2003, 05:42 PM   #6
Stocker
Re: brakes
Yup - but there's a way to do it without a C-clamp. Wedge a couple prybars or big screwdrivers at opposing angles against the pads and apply pressure. The pads will slowly move back in their bores.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
