Brake Pedal Feel - JeepForum.com
post #1 of 12 Old 11-13-2011, 05:54 PM Thread Starter
Bubba3200
Brake Pedal Feel
Wifes 2000 GC Larado and my 2002 Overland......the pedal feel on the wifes WJ is so much better than my WJ. Hers is firm and the pressure starts almost right away when you touch the pedal. Mind you have to push down some before the pressure starts to apply the brakes. I have read that the 2000 models had a better brake pedal feel and that the 2002 models had a more spongy pedal feel.
Question is can I replace parts from a 2000 to a 2002 and get the better pedal feel and if so what parts make up the pedal feel? Master cylinder?
Anyone have any ideas??
Bubba3200 is offline
post #2 of 12 Old 11-13-2011, 06:00 PM
Rocklobster
Im not sure what parts would be different but maybe its just the master cylinder as most of the parts from 99-04 are interchangeable...have you tried just bleeding your brakes
Rocklobster is offline
post #3 of 12 Old 11-13-2011, 06:25 PM Thread Starter
Bubba3200
The brakes are fine. I have read articles that state the pedal feel are different on the 2000 and 2002, and was wondering why. I love the feel of the wifes brake pedal.........no jokes please.....
post #4 of 12 Old 11-13-2011, 06:36 PM
Rocklobster
Check the part numbers of the masters see if there the same I guess
post #5 of 12 Old 11-13-2011, 08:05 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Thought it was on the 2003's, but they changed the master cylinder output pressure.
M/C part numbers are the same for a '03 and a '00 on Partsgeek, so some digging would have to be one I guess.
It was touted as an improvement to allow better braking with less effort BTW
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 12 Old 11-13-2011, 08:49 PM
fastfreddie
I can think of two items that could present this difference.
One, the Teves brake caliper. It's the original caliper for your wife's '00, It's black and it can be upgraded to the Akebono caliper(silver) that came with the later '02s and on. Depending on whether the Teves caliper pistons are a different diameter than the Akebono pistons, there could be a difference in feel.
Two, the anti-lock brake module is different.
So, if your wife's Jeep has silver calipers, the difference between the brake systems is in the module. Whether that would create the difference in pedal feel, I don't know.
I seem to recall a different, softer feel when I had my early '02 model Overland upgraded to the Akebono, but that was ten years ago. It could be that the dealer did a poor job of bleeding the system. Lately, I've been entertaining the idea of replacing the brake fluid and doing an anal job of bleeding the brakes. I only hope it makes a difference.
fastfreddie is offline
post #7 of 12 Old 11-14-2011, 01:59 PM Thread Starter
Bubba3200
Wifes car has the Akebono, so does mine when I switched the calipers I also did the rotors and pads and ran new fluid through both systems. So both Jeeps have the same calipers, rotors, brake pads and Dot-4 fluid...........So the 2003 master cylinder is different???
post #8 of 12 Old 11-14-2011, 03:26 PM
Rocklobster
You could have a small vaccuum leak ??? But I still think the masters could be different.
post #9 of 12 Old 11-18-2011, 05:01 PM Thread Starter
Bubba3200
So if I buy a master for a 2000 will it fit my 2002?
Checked parts stores for part numbers and the 2000 and 2002 master cyl are the same so it would fit, but would it give a harder pedal feel??
post #10 of 12 Old 11-18-2011, 05:53 PM
Rocklobster
Could have same number and different internals.
Almost every part between 99-04 is interchangeable
Sent directly from my brain using JeepForum
post #11 of 12 Old 11-18-2011, 09:40 PM
irzyxel
My 2004 Overland takes less pedal pressure for normal/light breaking than my 2000 Limited did. Not by a little. No noticeable difference between the two under hard breaking though.
Both Akebono. Both new pads, rotors, calipers. I don't have the Limited anymore, so if they had different master numbers I'll never know. Makes me more curious.
irzyxel is offline
post #12 of 12 Old 11-19-2011, 10:24 AM
indept
It could be the master cylinder, the brake booster (Vacuum), the antilock assy, or calipers so unless you want to go to great expense don't worry about it. As long as the pedal is "constant" meaning that you can't raise the pedal by pumping the brakes, which would indicate air in the lines & it always keeps that same level, there should be nothing to worry about. Check ALL of the brake hoses for cracks. There are a lot of hoses on the front, not just the ones on the calipers. They are double walled hoses so if the outer wall is cracked, which is common as any vehicle gets older, it could bubble out & cause the pedal to be lower. Also, check the steel hydraulic brake line that runs along the inside of the frame on the driver side. They are known for rusting out. That won't cause a low pedal but WILL eventually burst causing you to lose the back brakes. I just replaced mine, I noticed a lot of rust. It didn't burst yet but was close. If you DYI it's only about 15 bucks at the dealer for the exact replacement line.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
Brake pedal goes to the floor!!!!! Bubba3200 WJ Grand Cherokee Forum 22 11-22-2014 10:30 AM
Firming up the brake pedal Knoxes WJ Grand Cherokee Forum 22 11-23-2012 11:31 AM
'03 Brake Pedal Issue DSRKVR WJ Grand Cherokee Forum 5 09-01-2011 07:21 PM
Pedal Travel & Brake Pad Reccomendation gordon WJ Grand Cherokee Forum 4 04-19-2011 09:05 AM
Brake pedal hisses? JeeperCreeper94 WJ Grand Cherokee Forum 2 11-07-2010 07:46 AM
