!!!!!Brake lights stop working with headlights on!!!!!! - JeepForum.com
post #1 of 10 Old 09-05-2012, 05:30 PM Thread Starter
iamrion
Wj !!!!!Brake lights stop working with headlights on!!!!!!
Have an issue with my '01 Grand Cherokee Laredo where my brake lights will not illuminate when the headlights are on. The brake lights work fine without them on. The tail lights are illuminated when the headlights are on but go off when the brake pedal is applied, leaving me without tail lights or brake lights.
Could this be a fuse or wiring issue? I have looked at several fuses that I thought might be related but the ones I looked at seem to be fine. If anyone has any idea please let me know!
iamrion is offline
post #2 of 10 Old 09-05-2012, 06:59 PM Thread Starter
iamrion
UPDATE: For anyone who wants to know I have found the resolution to this problem. The piece that holds the bulb for the brake and tail light has a power and ground that it makes contact with when you insert it. If you pry those small pieces up just a bit and clean them up well it will solve the problem. Another post also suggested using a solder to make the contact point larger. I did not try this method, but the other individual said it worked for them.
iamrion is offline
post #3 of 10 Old 09-06-2012, 08:47 PM
Muggsie
I had the same problem with mine. In a pinch I just switched my reverse light plug and bulb and all the lights worked fine.
Muggsie is offline
post #4 of 10 Old 09-21-2012, 08:27 PM
orionife
1999 FSJ Cherokee
We had the same problem of the lights going out when the brake was pressed, but work fine with the head lights off. Just did the solder method on my sons 1999 Jeep Grand Cherokee and it worked! Thanks
orionife is offline
post #5 of 10 Old 09-22-2012, 02:53 AM
irzyxel
You should try the forum's search function. Glad you got it working. Very common.
2004 Overland stock with 103,000 miles
irzyxel is offline
post #6 of 10 Old 09-23-2012, 06:29 AM
orionife
1999 FSJ Cherokee
I did use the forums search function, that is how I found this thread to learn to try to solder.
orionife is offline
post #7 of 10 Old 09-23-2012, 02:43 PM
irzyxel
Yes and there are countless threads saying the same thing.
Sent from my hacked Kindle Fire using JeepForum
irzyxel is offline
post #8 of 10 Old 11-14-2012, 11:22 AM
egsauer
Thanks! Just did the solder method on my 99 WJ and it worked. Glad this forum is here and glad you folks are part of it.
egsauer is offline
post #9 of 10 Old 03-20-2015, 07:07 PM
madbulldogs
I have a similar problem with my wife's 2008 Grand Cherokee, when the headlights are off i have blinkers and when the headlights are turned on i no longer have blinkers or tail lamps, any one with any ideas?
madbulldogs is offline
post #10 of 10 Old 03-27-2015, 11:37 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Madbulldogs,
Do you experiencing this at night, day or all the time? If you have day time running lamps on your vehicle the headlamp will turn off to increase turn signal visibility, per page 154 of your Owner Manual.
JeepCares is online now
Closed Thread
Brake lights not working!!! foldsct WJ Grand Cherokee Forum 20 03-23-2016 06:32 PM
All brake lights not working fizzer WJ Grand Cherokee Forum 11 08-21-2014 03:09 AM
My brake lights are not working mallen13345 WJ Grand Cherokee Forum 2 06-15-2012 06:15 AM
Brake light not working when headlights on woowoowooty WJ Grand Cherokee Forum 2 02-13-2012 11:37 AM
headlights - check. brake lights - check. tail lights and running lights - FAIL. :( str8shot WJ Grand Cherokee Forum 6 11-14-2011 10:11 AM
