brake light problem - JeepForum.com
post #1 of 6 Old 04-22-2009, 11:06 AM Thread Starter
JackStraw
brake light problem
just noticed a problem with the brake lights on my wife's 99 g.c. the brake lights work fine when the headlights are off, but when you turn the headlights on, the brake lights no longer work. any ideas?
1999 Grand Cherokee 4.0
215,000 mi
Bone Stock other than K&N airfilter
JackStraw is offline
post #2 of 6 Old 04-22-2009, 01:58 PM
longboy
2006 WK
This has happened on my '99 2 times since I bought it. Both times the problem was solved with a new bulb socket that I purchased from the dealer ($10 or so).
Is this on both sides, or just one side?
2006 5.7l WK
longboy is offline
post #3 of 6 Old 04-22-2009, 06:35 PM Thread Starter
JackStraw
both sides. you've had to do it twice, you think there is something shorting it out?
215,000 mi
post #4 of 6 Old 04-22-2009, 07:41 PM
longboy
2006 WK
I have no idea, nor do I plan on doing much about it
It has happened 2 times in about 89k miles, and if it costs me $10 every 45k I'm ok with that honestly.
2006 5.7l WK
longboy is offline
post #5 of 6 Old 04-23-2009, 09:30 AM Thread Starter
JackStraw
cleaned and bent the contacts back up on the bulb socket, working good now
215,000 mi
post #6 of 6 Old 06-23-2010, 09:50 PM
NYjeepster24
I'm just posting this bc I asked some time ago and nobody knew what the issue was. I found this so this is not my work. I thought my light didn't work when I turned on the car but it was really just when my lights were on(of course the worst time). Found this on another forum and saved a good deal of money. This may have already been posted but just wanted to make sure. Seems to be a very common issue.
Jeff | Jan 27, 2007 | Reply
First, I want to say thank you for the info, you saved me money and aggravation. Second it took mea little while to figure out what contact I was looking for. So I would like to provide a little more detail to make it easier for others in the future.
This is the corrective method for your brake lights not working when your headlights are on(2000 Jeep Cherokee Larado).
1) The cause of the problem is heat from the bulb.
2) Remove the light assembly as if you were going to change a bulb.
3) Turn the socket and remove it from the taillight assembly and set it aside(check to be sure your bulb is not burnt out).
4) Look at the opening, you will see 3 flat chrome colored contacts on the assembly.
5) Notice the one by it self at the top of the opening, that is the “ground”.
6) If you look closely you will notice the plastic around the ground contact has shrunk a little bit, this caused the contact to pull away from the socket, causing the problem.
7) With a small flat head screwdriver, VERY GENTLY pry up the contact so it stays slightly upward by itself.
8) Re-insert the bulb assembly back into the housing and press your brake petal with your lights on.
9) You should be in good to go!
10) Tools: Phillips head screwdriver and a small flat head screwdriver.
11) Time : 5 minutes per light
NYjeepster24 is offline
Brake light problem grovesj2 ZJ Grand Cherokee Forum 9 07-03-2010 02:52 PM
Brake light problem. kbsjeep99 ZJ Grand Cherokee Forum 2 06-08-2008 07:33 PM
Brake Light problem RobSmith ZJ Grand Cherokee Forum 0 05-06-2008 06:05 AM
Brake light problem, need help! shahriarrrr ZJ Grand Cherokee Forum 5 03-05-2008 07:08 PM
brake light problem Saint18z ZJ Grand Cherokee Forum 1 04-24-2006 08:40 AM
