Brake light not working when headlights on - JeepForum.com
post #1 of 3 Old 02-13-2012, 07:52 AM Thread Starter
woowoowooty
Hello. I have had this problem but have fixed it by pulling the connector up and it worked fine for a while. Now it is doing the same thing and when I checked the the connector, it was still pulled up. At this point I am thinking the only thing I can do is buy a new tail light, which I don't want to do. Has anyone else had this problem where it has already been fixed, but the light still isn't working? Any help will be greatly appreciated.
woowoowooty is offline
post #2 of 3 Old 02-13-2012, 10:34 AM
Ideford Jeep
If the brake light works fine when the headlights are off, it's often an earthing fault - try running another earth from the light unit to the body.
Ideford Jeep is offline
post #3 of 3 Old 02-13-2012, 10:37 AM
speedyjeep
Could just be a fuse issue, maybe try swapping out your brake light fuse
'00 Jeep Grand Cherokee Limited 4.7L V8 4x4,
-Shocks = Edelbrock 3321(Front)/34404(Rear)
-Direct fit high-flow magnaflow catalytic converter
speedyjeep is offline
All brake lights not working fizzer WJ Grand Cherokee Forum 11 08-21-2014 02:09 AM
Brake lights not working rachel12 WJ Grand Cherokee Forum 1 01-03-2012 12:21 PM
Second post: Tail light/brake light problem gld1203 WJ Grand Cherokee Forum 3 07-24-2011 06:23 AM
Brake light short when headlights on nikknkeet WJ Grand Cherokee Forum 0 09-24-2010 09:10 PM
brake lite off w/headlights on novacats WJ Grand Cherokee Forum 4 06-23-2010 09:54 PM
