Brake Jobs (No rotors) - Page 2 - JeepForum.com
post #16 of 22 Old 08-27-2014, 08:58 AM
mycreativename
Originally Posted by Jayybirdd View Post
I need to do my brakes and rotors.
Isn't there a special kind that won't make awful noise when shifting gears?
I need to bleed my brakes too
Why would your brakes make noise when shifting gears?
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #17 of 22 Old 09-01-2014, 10:59 AM
andrewx12
+1
Also why do you need to bleed them? The only time that is needed is when you take off one of the lines. You don't need to remove the lines from the calipers on this car to change pads and rotors
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #18 of 22 Old 09-01-2014, 12:19 PM
Jayybirdd
To get any air out possibly. The brakes are too soft. When I put in drive or reverse , the brakes make an awful noise
Jayybirdd is offline
post #19 of 22 Old 09-01-2014, 12:35 PM
mycreativename
Alright, I guess I could see flushing the lines if you wanted to get new fluid in them, (actually a good practice about once every two years).
When you say noise when going into gear, is it a clunk? If so, that to me sounds more like U-joints than brakes.
post #20 of 22 Old 09-01-2014, 06:52 PM
Jayybirdd
Not a clunk. Try to get a video
post #21 of 22 Old 09-02-2014, 01:19 PM
Acc0919mc
My and my fathers WJ both groan from the rear brakes when you put them into gear. It is also annoying me if this is what you are taking about
2000 4.0L WJ "PB" - 2.5" Dynomax Catback - K&N Factory Air Filter - All Synthetic Fluids -Cooper Discoverer AT3's - 1" Addco Sway Bar
Acc0919mc is offline
post #22 of 22 Old 09-02-2014, 05:10 PM
Jayybirdd
http://youtu.be/wwL3Q_WvJas
I'm moving here.
When I'm on a hill it is even worse. I have the brake to the floor. It sounds like the are just dry lol. I was putting the boat in, and my goodness what a noise. Made the cows start mooing
