Brake Jobs (No rotors) - JeepForum.com
post #1 of 22 Old 08-25-2014, 08:46 PM Thread Starter
thanser
When was the last time you had a brake job done and didn't have to replace the rotors?
I can't see the pads themselves within the calipers so how can you tell if you're in need of a brake job? I just picked up a used Grand Cherokee with 106k on it. After an initial inspection by the dealer there was no mention of the pads needing replaced. Everything's fine for now, but...
I'd like to have the pads replaced before they score the rotors and have to replace them.
So, a Jeep Grand Cherokee has a brake wear sensor? How accurate is it and how does it indicate your pads are worn?
Tired of spending too much on brake pads AND rotors.
Thanks.
thanser is offline
post #2 of 22 Old 08-25-2014, 08:55 PM
mycreativename
What on earth are you talking about with the brake wear sensor? I think you might be thinking of a squeeler, the little piece of metal that attaches to the pads and will contact the rotors and make a hell of a noise when they are getting low.
Best and only good way to check in my opinion would be to just take wheels off and check by hand. You can look down through the top of the caliper and see the pads and how much material is left that way.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 22 Old 08-25-2014, 09:43 PM
losttech
losttech's Avatar
Honestly basic rotors are cheap really no reason to not replace them if doing pads.
I think my duralast ones were like 16 each with lifetime warranty.
losttech is offline
post #4 of 22 Old 08-26-2014, 05:43 AM
Double E
Double E's Avatar
^ +1. Remove wheel & inspect for yourself is best. AS OEM configured there is no squeal device that I'm aware of.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
post #5 of 22 Old 08-26-2014, 06:57 AM
logisticalstyle
I just realized how cheap rotors can be. I found them locally for 35.00 each. For some reason I was thinking they were going to be 70 or 80. I'll be replacing pads and rotors very soon.
logisticalstyle is offline
post #6 of 22 Old 08-26-2014, 07:35 AM
Jeeples
Jeeples's Avatar
Even if you don't have to replace the rotors due to them exceeding the minimum thickness spec, you should have them resurfaced whenever you change out the pads. How much life you get out a set of rotors and pads really depends on your driving habits, function of the rest of the brake system, pad compound and rotor quality.
While some vehicles use an actual brake pad wear sensor (a glorified magnet that gets placed in the pad and triggers a service light when the pads wear and the magnet gets closer to the rotor), WJ's do not have such a feature. Some aftermarket pads include a cruder version of this in the way of a small metal tab that is a attached to the side of the pad back plate and as the pad wears the tab will contact the rotor and make a squealing or squeaking sound when the brakes are applied.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 22 Old 08-26-2014, 07:39 AM
Turbozcs2003
Just buy new rotors, summit had Rabestos Pro rotors for 12.50 clearance, I grabbed a set for all my cars.
Turbozcs2003 is offline
post #8 of 22 Old 08-26-2014, 09:32 AM
Jeeples
Jeeples's Avatar
^ Thanks for the heads up
Jeeples is offline
post #9 of 22 Old 08-26-2014, 10:43 AM
JMZ101586
Links? I cant find them.
Stable:
04 WJ Special Edition 4.7
98 Camaro SLP SS with LS2 swap
05 STS4 4.6 Northstar AWD
JMZ101586 is online now
post #10 of 22 Old 08-26-2014, 11:00 AM
Acc0919mc
People have the warping problem on the front wheels. I have never had a rotor warp on my WJ and i have the crappy non-akebono calipers (their name escapes me at the moment) I think its because i do all small town and highway driving
Acc0919mc is offline
post #11 of 22 Old 08-26-2014, 01:00 PM
Robertc2012
ATE = Al Teves
Robertc2012 is offline
post #12 of 22 Old 08-26-2014, 01:09 PM
Acc0919mc
Originally Posted by Robertc2012 View Post
ATE = Al Teves
That would be it Thanks!
post #13 of 22 Old 08-26-2014, 08:04 PM Thread Starter
thanser
Thanks, everyone.
I haven't done my own brake in over twenty years, so I take it in when I have to.
thanser is offline
post #14 of 22 Old 08-26-2014, 11:11 PM
andrewx12
Originally Posted by thanser View Post
Thanks, everyone.
Disc and caliper are 100x easier than dealing with the drums, shoes, and springs that you are probably remember servicing.
Just make sure that the caliper pins are cleaned then greased when you do it. Otherwise they could cause the rotors to warp, overheat, or just plain mess stuff up if they don't move properly.
Regardless of whether or not you do them yourself. Make sure that those pins are lubed up in the front.
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #15 of 22 Old 08-27-2014, 08:50 AM
Jayybirdd
I need to do my brakes and rotors.
Isn't there a special kind that won't make awful noise when shifting gears?
I need to bleed my brakes too
Jayybirdd is offline
