Brake Caliper Slide bolt Stuck - Page 2 - JeepForum.com
post #16 of 20 Old 01-26-2013, 11:24 PM
cj71210
Another thing that u can do if all else fails is drill a hole on the outside part of the caliper lining up were the slide Wld be and then punching it out with a hammer and then patch hole up when done iv just used rtv to plug the hole in the past. Does anything get what I'm trying to say haha
cj71210 is offline
post #17 of 20 Old 01-27-2013, 02:53 PM
Gunrunner23
What kind of guide pin do I want? There's some oversized self tapping ones and then ones with a gold colored screw?
Sent from my Motorola Photon using JeepForum
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #18 of 20 Old 01-27-2013, 03:51 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I have new drilled rotors,Hawks pads and new slide pins for sale. My cost was $265 will sell for $225.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #19 of 20 Old 01-27-2013, 04:58 PM
Darnice
pins and boots every pad change is a good idea. If it seized that tight, replace the bracket too.
Darnice is offline
post #20 of 20 Old 06-08-2013, 06:55 AM
SteveInChicago
The lower pins on both sides of my 2000 front calipers were seized. A pipe wrench, long cheater bar, PB blaster, some heat, lots of time working the problem eventually got them off. I'm amazed they didn't snap with the amount of torque I had to apply to them. Since I didn't have new pins on hand, I cleaned the corrosion off the old pins and reassembled with antiseize. Since then I've sourced new pins AND the rubber boots that keep water out. Now I have to go back in and do it all over to get the new pins in. I'm sure the lower holes are corroded as bad as the pins that came out so I want to clean them up back to original tolerances. Since the upper holes were fine, I'm going to use them to select a drill bit size that fits snugly (I have one of those drill bit kits that has more sizes than there are people in New York). Then I'll chase the lower holes with that bit to be sure the corrosion is removed and they are opened back up to the same size as the upper holes. When iron corrodes, it expands (making the hole smaller). I'm not drilling the holes bigger, just drilling out the corrosion so they are back to the original stock diameter. The antiseize will get flushed out with Brake Kleen and the new parts installed with the correct type of brake pin grease. I think the problem was caused by the rubber boots. They were deteriorated and letting water in.
SteveInChicago is offline
Stuck caliper piston? brianestep WJ Grand Cherokee Forum 6 06-17-2011 04:27 PM
teves caliper stuck Geo-Nemesis WJ Grand Cherokee Forum 5 06-13-2011 06:02 PM
Brake Caliper cgillett81 WJ Grand Cherokee Forum 3 05-01-2011 09:16 PM
Stuck Rear Caliper Causing Squeak Noise? swataz WJ Grand Cherokee Forum 2 08-22-2010 12:32 PM
04 GCL rear caliper bolt size? georged WJ Grand Cherokee Forum 0 07-31-2010 05:54 AM
