Brake Caliper Slide bolt Stuck - JeepForum.com
post #1 of 20 Old 07-06-2011, 10:47 AM Thread Starter
dinovass
I have a 2001Grand Cherokee that recently started making horrible grinding noises from the drivers side wheel. It turns out the slide bolt got stuck partially extended and the brake pad started rubbing at an angle instead of flush with the rotor. One slide bolt works perfectly while the other one is stuck solid. Is there a good way to dislodge the bolt. I tried prying it out, twisting and resorted to a hammer with a blunt chisel. Nothing is working. Do I try hitting it harder or is there a correct way to remove it.
Thanks
dinovass is offline
post #2 of 20 Old 07-06-2011, 11:25 AM
FirefightinWJ
Heat, PB Blaster, and Vice Grips.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #3 of 20 Old 07-06-2011, 05:15 PM Thread Starter
dinovass
Thank you. Added hammer and chisel to your list and 2 hours later dislodged the bolt but destroyed the rubber boot in the process.
dinovass is offline
post #4 of 20 Old 07-06-2011, 05:17 PM
mtnmarc
my remanned calipers did the same thing. i tried hitting it with a hammer, pliers, everything. i ended up just getting a new caliper and mounting bracket under warranty.
maybe clean them regularly with brake clean then re lube them. the rubber boots might be loose letting dirt and other contaminates in.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #5 of 20 Old 07-06-2011, 07:34 PM
FirefightinWJ
Thats the big thing. Everytime I remove a brake caliper, I pull the slide pins and cover them with anti-seize.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
-Devin
post #6 of 20 Old 07-07-2011, 11:10 PM
djoy
not to hijack but I couldn't get the bolt that goes from bracket to knuckle off. Used heat and acetone/atf. I felt like I was going to shred the bolt so I gave up. This was with a nice big cheater bar.
djoy is offline
post #7 of 20 Old 12-17-2011, 12:34 PM
Iieyasu1
I couldnt get my bolts off either. PB, hammer and light tapping. Next up breaker bar and air gun. These bolts are comin off.
Iieyasu1 is offline
post #8 of 20 Old 12-17-2011, 05:36 PM
djoy
I finally got them off using a wrench and a 5lb hammer. It worked like a charm and since the wrench goes around the entire bolt nicely, they wont strip easily . Using an impact almost destroyed what was left and the wrench rescued them. But the first three blows the hammer did bounce as if it were a bungee.
djoy is offline
post #9 of 20 Old 12-17-2011, 07:19 PM
Augie56
Yep, the best way would be to use an impact with just enough air pressure to break them free, but thats about impossible with the clearance you have to work with.
In cases like this, I like to create my own impact with 1/2" six point sockets and my short handle 5lb sledge. Works every time.
Augie56 is offline
post #10 of 20 Old 12-17-2011, 08:09 PM
kastner03
anit-seize is a bad thing to use on the slide pins from what i was told by all the mechanics at a local garage, it will kinda dry up and collect dust. they make grease just for this purpose and it works really well since ive switched to using the grease ive never had any dirt build up in there or rusted/stuck guide pins, we service a fleet of about 15 plow trucks and every fall we used to always have stuck guide pins when wed service the trucks before winter, this year not a single one!
kastner03 is offline
post #11 of 20 Old 12-17-2011, 09:35 PM
ct-snoman
2003 WJ
you want to use slide pin/brake lube. It is designed specifically for that purpose and, equally if not more important, is designed to withstand the heat that is generated by the brakes. Any other lubricant and you run the risk of bad things happening
ct-snoman is offline
post #12 of 20 Old 12-18-2011, 01:34 PM
Augie56
I use white lithium on all the pad contact points and the slide pins. So far, so good...
Augie56 is offline
post #13 of 20 Old 01-26-2013, 08:08 PM
teamodave
I just did the front brakes on my 2004 Grand Cherokee and each side had one slide pin that did not want to budge. I wasted a good hour trying to get the first one off when I finally mounted the bracket back on the knuckle and used a pipe wrench and a cheater bar to break it loose. Once loose, I hit it with Liquid Wrench, and more twisting with the pipe wrench. When I had enough room to not ruin the rubber boot, I used channel locks to keep turning it. Then I'd used a flat chisel and mini sledge hammer. Eventually it broke loose. The second one was just as seized but I got it at last. All in all, it ended up being a 5 hour job but I was glad I stuck with it as I didn't have a back up car to get to work on Monday.
teamodave is offline
post #14 of 20 Old 01-26-2013, 08:15 PM
Gunrunner23
Would one suggest getting extra slide pins before they change their brakes? Im about to do them and I want to have everything in case I run into problems.
Sent from my Motorola Photon using JeepForum
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #15 of 20 Old 01-26-2013, 09:18 PM
teamodave
I did and I'm very glad I did. Might not hurt to get the boots along with them, but I got lucky and didn't need them. Make sure you have some good brake grease and some anti-seize compound too.
Stuck caliper piston? brianestep WJ Grand Cherokee Forum 6 06-17-2011 05:27 PM
teves caliper stuck Geo-Nemesis WJ Grand Cherokee Forum 5 06-13-2011 07:02 PM
Brake Caliper cgillett81 WJ Grand Cherokee Forum 3 05-01-2011 10:16 PM
Stuck Rear Caliper Causing Squeak Noise? swataz WJ Grand Cherokee Forum 2 08-22-2010 01:32 PM
04 GCL rear caliper bolt size? georged WJ Grand Cherokee Forum 0 07-31-2010 06:54 AM
