Brake booster question - JeepForum.com
post #1 of 9 Old 12-21-2013, 02:46 PM Thread Starter
Cashless45
Hey guys, I'm new to this forum and have a question. I have a Grand Cherokee Limited with the 4.7ltr V8. The brake booster needs to be replaced. Question. Can I get it out without having to remove the master cylinder?
Cashless45 is offline
post #2 of 9 Old 12-21-2013, 02:51 PM
MadderThanMax
Yes... but its more awkward than taking it out as one assembly and working with on a bench etc..
MadderThanMax is offline
post #3 of 9 Old 12-21-2013, 06:19 PM Thread Starter
Cashless45
Not convinced
Well, after two hours, I'm not convinced it will come out. I took the vapor canister out to make room . Still not enough room with the master cylinder removed. How hard is too bleed the system from the master cylinder?
post #4 of 9 Old 12-21-2013, 06:29 PM Thread Starter
Cashless45
I'm still trying. Couple of questions. If I pull the air box can I move the whole master cylinder/ ABS module forward can the booster come out ? More details would be very helpful. Thanks again
post #5 of 9 Old 12-22-2013, 04:12 AM
MadderThanMax
Can you get some photos up please?
post #6 of 9 Old 12-22-2013, 05:07 AM
alfaitalia
Hey max......if they had the steering wheel on the correct side over there it would be an easy job. My MC is nowhere near my abs unit!
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #7 of 9 Old 12-22-2013, 05:52 AM
MadderThanMax
Only tryin' to Help D... done a few of them in the past...
post #8 of 9 Old 12-22-2013, 07:03 AM
Darnice
To the OP, what makes you think the booster is bad? Just curious.
Darnice is offline
post #9 of 9 Old 12-22-2013, 07:34 AM
doityourselfMM
doityourselfMM's Avatar
It can be removed but you really have to rotate the master cylinder 90 degrees. A little man handling is required getting the brake booster out. Can you say twist and turn. The flex lines between the MC and the ABS HCU are what gives you the access. I did it several weeks ago. I didn't think I could get it out, but I did.
Removing the air box won't help. All the hard brake lines will remain in place even with the air box removed. Pulling the MC out all together will make the job very easy, but then you may need to bench bleed the MC, and bleed the entire brake system.
Do a search for brake booster. There are many threads.
doityourselfMM is offline
