bolts that hold driveshaft to rear end - JeepForum.com
post #1 of 8 Old 10-24-2013, 04:12 PM Thread Starter
jaybob1807
Hi, I just replaced the output seal from the tansfer case and i am wondering what the bolts that hold the rear u joint to the differential with the straps need to be torqued to? I know that wjjeeps has a ton of info on our vehicles but I am not even sure what to call those little bolts with the straps. So I dont know what to torque them to. Thanks
jaybob1807 is offline
post #2 of 8 Old 10-24-2013, 05:30 PM
Darnice
Manual says only 14 ft-lbs.
Darnice is offline
post #3 of 8 Old 10-24-2013, 06:03 PM Thread Starter
jaybob1807
That sure doesn't seem like much. Makes me a little nervous
post #4 of 8 Old 10-24-2013, 06:23 PM
MuddyWJ
Throw red loctite in there and your good. I haven't heard of anyone dropping a shaft yet. You'll be fine.
MuddyWJ is offline
post #5 of 8 Old 10-24-2013, 06:32 PM Thread Starter
jaybob1807
How about blue
post #6 of 8 Old 10-24-2013, 06:35 PM
mycreativename
They're small bolts, I wouldn't expect them to be that high, so 14 sounds about right.
I didn't even loctite mine and its been years of them just being "tight-nuff".
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #7 of 8 Old 10-24-2013, 07:45 PM
Duh
None of us at the shop would ever torque them. Tighten by hand with a standard ratchet and call it a day.
Duh is offline
post #8 of 8 Old 10-24-2013, 10:04 PM
Cirruslydakota
14 ft-lbs and blue loctite. Dont forget to clean the old threadlock out of the threads.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
