Bolt size - JeepForum.com
post #1 of 4 Old 08-18-2013, 09:45 AM Thread Starter
PHAL23
Bolt size
What is the size of the bolts for the lower control arms? I'm jut gonna be cutting them off and replacing them since the others don't seem to want to come off, so before doing so I'd like to just have the other bolts ready. Ill be replacing all the bolts on both front and rear lower control arms
PHAL23 is offline
post #2 of 4 Old 08-18-2013, 11:31 AM
Woliwi
BOLT. Lower Control Arm. M12, M12x135. .
JEEP GRAND CHEROKEE.
BOLT, (12X135), BOLT, (12X135-10T), BOLT, Frt. Ssup. Lower Arm (12x135).
Stock Code MB242334
Manufacturer Chrysler
This is the stock size....Not sure of the upgrade metric equivalent.
Old Man Emu HD Springs * Bilstein 5100/5125 Shocks * Iron Rock Adj. LCA's & UCA's * JKS Adj. Trackbar w/ KOR Durometer Bushings * Moog Super Trail Boss Steering Stabilizer * Addco 1" Anti-Sway Bar w/ Energy Bushings * IRO Rear Ext. Endlinks * KOR .75 Front Poly Spacer * Falken Rocky Mountain LT 265/75/16 ATS on stock Silverblades #1
Woliwi is offline
post #3 of 4 Old 08-18-2013, 12:08 PM
Merc1973
Or upgrade to Grade 8 SAE:
Front:
Upgraded UCA axle bolts to: 2.5" x 7/16"
Upgraded UCA frame bolts to: 2" x 7/16"
Upgraded LCA axle & frame bolts to: 4 1/2" x 9/16"
http://www.jeepforum.com/forum/f310/...thread-314066/
FYI, the stock front LCA Bolt at axle and at frame is different, the axle end is longer.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #4 of 4 Old 08-18-2013, 12:51 PM Thread Starter
PHAL23
I think ill upgrade to grade 8 considering I can't find any of the others in any hardware stores and nobody seems to help you there either. Thanks for the reply
PHAL23 is offline
